Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Like Tree8Likes
Thread: pipe symbols in medium and corse view settings
  1. #11
    Member Darius's Avatar
    May 6, 2013
    455
    12:02 AM
    thanks to those who have help on this issue. I have been busy at work and have had some time to try things and have been slowly converting families
  2. #12
    February 22, 2013
    238
    12:02 AM
    Quote Originally Posted by tzframpton View Post
    I can't stand the annotative ticks. I modified the Family and hid the ticks. In fact, I even did away with the "radius" schematic line and just created two mitered schematic lines so the elbows have a hard corner. Makes the linework so much cleaner on the drawings.
    -TZ
    I've done the same thing for our "pressure pipe", i.e. domestic water, hydronic, etc. For our DWV piping, I made elbows that insert a 45░ chamfer when the bend angle is close to 90░. Our Tee families will also show a dot at the intersection for pressure pipe, or for the chamfer for the DWV fittings. All of this took a LOT of time to get working correctly. Of all the kinds of Revit families, pipe fittings are the ones I hate working with the most!
    At first we simply believed that Revit's single-line piping capability was "broken" and didn't use it all, which of course made our 1/8th scale drawings look like crap. It wasn't until I started digging into how the lines in elbow families worked that I was able to get it looking like something approximating our CAD content.
  3.    #13
    June 14, 2011
    CT, USA
    496
    12:02 AM
    Sorry to dig this older thread up but I haven't been successful in creating the mitered symbol. I've got a feeling I'm missing something quite basic.
    Would you mind sharing an elbow with me, TZ?
  4.    #14
    January 17, 2011
    1,859
    11:02 PM
    Here you go Rob.
    (Version is 2015)
    Attached Files Attached Files
  5.    #15
    June 14, 2011
    CT, USA
    496
    12:02 AM
    Thank you. I'll have a look when crunch time for this project is over.
    tzframpton likes this.
  1. Pipe Settings dialog vs Pipe Systems
    By Ch2M_MikeMaloney in forum MEP - General
    Last Post: December 7th, 2015, 09:00 PM
  2. Turn Off Pipe Settings
    By andyrh1982 in forum MEP - General
    Last Post: August 17th, 2015, 03:49 PM
  3. Help with changing size of pipe up and down symbols
    By dfolk in forum MEP - General
    Last Post: March 18th, 2013, 11:18 AM
  4. vertical conduit circle size in medium view
    By Ning Zhou in forum MEP - General
    Last Post: July 5th, 2012, 09:10 PM
