Results 1 to 7 of 7
Like Tree4Likes
  • 1 Post By Steve_Stafford
  • 3 Post By cganiere
Thread: Random Crash
    Member koolair's Avatar
    July 31, 2014
    263
    06:30 PM
    Random Crash
    This is not my day. First my Revit crashes and I lost 1.5 hrs of work.
    Then I come here to post my frustration and I hit backspace and the window goes back to the thread list. Post is gone.
    Anyhow, I lost a bunch of detail work. Is there any way I can recover it?
    I got no error message.
    I was zooming and panning then suddenly *poof*.
    I can see a .slog file date/time stamped 5 hours ago, an eperms.dat file stamped 20 min ago.
    Any ideas?
    Thanks...
    Mr. Revit OpEd
    2,912
    03:30 PM
    Sorry, not good...waiting 1.5 hours between saves. No save no backup to rely on unfortunately... Save...save often
    July 31, 2014
    263
    06:30 PM
    Quote Originally Posted by Steve_Stafford View Post
    Why I just want to know - aside from saving often - what the problem is. Why does Revit like to crash?
    I've been using Revit for 6 years. I know it likes to crash.
    Usually I only lose 20-40 minutes of work. And that's not insignificant. A lot happens in 15 minutes.
    There's got to be a recovery technique.
    Anyways, I'm not in the mood to get back into more modeling tonight. Cheers...
    Mr. Revit OpEd
    2,912
    03:30 PM
    What version (version number, I'm assuming MEP because you're in this forum) are you using?
    What sort of computer specs are you dealing with? Revit hasn't crashed on me in quite a long time. I realize that doesn't make you feel any better but it should not normally crash.
    Revit is vulnerable to the lack of memory and to video card/driver incompatibility. If you are getting a vanishing act where Revit was there one second and gone the next that suggests a memory issue (to me at least). Once it runs out...it's out... Any error messages or warnings about running low on virtual memory?
    Some years ago I noticed, when I was using Revit 2013, that it seemed to be prone to crashing when I used the middle mouse button and Shift key to spin a 3D view. When I updated the mouse driver and video drivers that problem stopped happening.
    Also what operating system are you using? Does it have all its shots? When Autodesk patches their software they claim they are also taking into account things that have changed in the Operating Systems it supports. This means applying patches to Revit on a PC that is wildly out of sync with its OS updates can make it even less stable.
    If you are using an older release of Revit...press to get your project upgraded. It might be inconvenient but everyone on the project will benefit because the 2015/2016 releases have improved performance dramatically...and then there are all the other little things that have come along too.
    koolair likes this.
    Member cganiere's Avatar
    January 5, 2011
    Orange County, California, USA
    212
    03:30 PM
    I've started noting the crashes of software on my Outlook Calendar. No Revit crashes yet this year. 4 ACA crashes.
    cellophane, tzframpton and koolair like this.
    July 31, 2014
    263
    06:30 PM
    I'm on Revit 2014. All updates installed, and yes it's the old vanishing act. Thanks for the tip.
    My computer in short - the best I've ever had - Dell Precision M-4700.
    I remember the 2013 crashes.
    January 5, 2011
    212
    03:30 PM
    I'm using ACA & Revit 2013.
  1. Revit 2015 - Random Freeze
    By cheinaranta in forum Architecture and General Revit Questions
    Last Post: September 25th, 2015, 09:48 PM
  2. random screening wall
    By ciesca in forum Architecture and General Revit Questions
    Last Post: April 12th, 2015, 04:05 PM
  3. Random snapping and cut-backs
    By caseym in forum Structure - General Questions
    Last Post: March 10th, 2014, 04:35 PM
  4. Random GUI element when opening or synching
    By Steven Thedens in forum Architecture and General Revit Questions
    Last Post: May 23rd, 2013, 01:19 PM
  5. Random Window & door Heights
    By mark b in forum Architecture and General Revit Questions
    Last Post: December 11th, 2010, 08:10 PM
