Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By GabrielChiew
Thread: Emergency lighting
    May 31, 2012
    Syracuse, NY
    179
    07:06 AM
    Emergency lighting
    Using rvt 14'
    I cannot for the life of me find a emergency lighting family that is not wall hosted pre 11' or what ever is it (no longer oriented correctly when upgraded to 14') OR i get a IES file Parse error no matter what IES file i seem to put in the family
    using elumtools
    does anyone have a family that works that i can use?
    spec'ing something similar to this:ELT - Titan® Die-formed Steel Emergency Unit
    Member Lkenshalo's Avatar
    March 27, 2014
    Seattle, Wa
    248
    02:06 AM
    So just to be clear - you need a face based emergency light that was made in a Revit 2011 release or earlier?
    May 31, 2012
    Syracuse, NY
    179
    07:06 AM
    Quote Originally Posted by Lkenshalo View Post
    that same family keeps popping up everywhere
    it is not oriented correctly
    it comes in as the instance on the left, i rotated but it still is hosted from the bottom of the fixture
    March 27, 2014
    Seattle, Wa
    248
    02:06 AM
    Try this.
    It may take some additional massaging to get it just right.
    Attached Files Attached Files
    May 31, 2012
    Syracuse, NY
    179
    07:06 AM
    Try this.
    I'm in 14', can't open
    March 27, 2014
    Seattle, Wa
    248
    02:06 AM
    Whoops - try this one.
    March 27, 2014
    Seattle, Wa
    248
    02:06 AM
    Did this end up working for you WG?
    May 31, 2012
    Syracuse, NY
    179
    07:06 AM
    ya sorry i didnt get back to ya
    still having trouble with IES files which is kind of the real issue
    not sure if its me or the ies files that are being provided??
    March 27, 2014
    Seattle, Wa
    248
    02:06 AM
    I've had some issue with IES files showing inaccurate(low) lighting levels in Revit even when the same IES is used successfully in another program(elumtools, visual, etc..), but it sounds like you're having a different issue.
    Hope someone can elaborate on the 'parse error'.
    Any chance you could post the exact error message you're receiving?
    February 15, 2019
    1
    07:06 PM
    I know I am 4 years late but i have made some slight change to the family. It should now be a wall-mount, parametric and aethestically closer to the original family.
    Hope it helps somehow or for whoever is searching for an emergency light in the future.
    cellophane likes this.
  1. Replies: 3
    Last Post: April 7th, 2016, 07:24 AM
  2. Do you have any difficult family that needs to go to the Emergency Room?
    By Alfredo Medina in forum Architecture - Family Creation
    Last Post: May 15th, 2014, 02:16 AM
  3. Emergency Lighting battery pack, remote heads & exit signs
    By skoko in forum MEP - Family Creation
    Last Post: June 19th, 2013, 02:05 PM
  4. Revit OpEd: Emergency Designation for Families
    Last Post: December 7th, 2012, 01:15 PM
