Results 1 to 6 of 6
Like Tree3Likes
  • 1 Post By MPwuzhere
  • 2 Post By MPwuzhere
Thread: Can't Edit a Nested Family without the Original file that was nested.
    July 11, 2014
    46
    06:19 PM
    Question Can't Edit a Nested Family without the Original file that was nested.
    I have a fan unit family (file B) that was created originally as a different file (file A) and nested into File B. File A is now no longer available.
    I would now like to edit the family but the 'Edit Family' button does absolutely nothing and I cant get back to the file that was nested. Is this because the original file A is no longer available?
    Is there any way to edit File A again? I thought you would just be able to edit the nested elements.... no?
    Michael
    Coeur d Alene, ID
    4,814
    10:19 AM
    Sounds more like it was an inserted DWG....it's the only time the "Edit Family" button won't work.
    Lkenshalo likes this.
    Member Lkenshalo's Avatar
    March 27, 2014
    Seattle, Wa
    248
    08:19 AM
    Could you post the family?
    You should be able to open the host family and then right click on the nested family to edit. The nested family isn't externally referenced so it shouldn't make a difference that it is no longer available.
    July 11, 2014
    46
    06:19 PM
    It's definitely not an inserted dwg. I made it myself using standard family creation methods i.e. extrusions, revolves etc. I got rid of the saved nested family as I didn't think it was needed. Now I can't get into the model to edit it.
    Actually it's a Revit 2015 file but thats not the issue.
    Here's a video of the problem in case you cant open the file. Both right click--> Edit nor clicking the Edit family button does absolutely nothing.
    Click Here for Video
    Attached Files Attached Files
    Coeur d Alene, ID
    4,814
    10:19 AM
    Okay....that is weird....
    Rename the nested family in the project browser...then it will work...
    mrgrotey and Lkenshalo like this.
    July 11, 2014
    46
    06:19 PM
    Awesome! it works!
    Only works if you rename the collapsible name, not it's 'child' as in the image below...
    Can't Edit a Nested Family without the Original file that was nested.-capture.jpg
    Thanks so much you're a lifesaver!
  1. Family Editor changes 2012 - 2014. Constraint to nested family broken.
    By Duncan in forum Architecture - Family Creation
    Last Post: May 4th, 2017, 10:35 PM
  2. Face Based Family with only a Void Nested into a Generic Model Family
    By Joshua Kohl in forum Architecture - Family Creation
    Last Post: October 18th, 2016, 02:12 PM
  3. Replies: 5
    Last Post: April 2nd, 2014, 07:59 PM
  4. Doors for download, Nested Panels and Nested Frames..
    By Twiceroadsfool in forum Architecture - Family Creation
    Last Post: May 28th, 2013, 09:51 PM
  5. Exploding file size with nested components
    By mdradvies in forum Architecture - Family Creation
    Last Post: February 23rd, 2011, 08:02 AM
Tags for this Thread
