Results 1 to 4 of 4
Thread: Air Terminal On Duct issues
    January 17, 2011
    1,994
    06:50 AM
    I have some drum louvers Air Terminal Families that are attached directly on the side of various instances of ductwork. The problem I'm having is that any time you want to make a change to an Instance Based or Type Based parameter it throws an error, stating: "The Air Terminal must be attached to duct" with only two actionable options, either delete the Air Terminal or Cancel the operation. So the trick is, have all your terminals pre-edited before you attach.
    Some Air Terminals do this and some don't. The stock Autodesk ones do not have this issue. Any ideas on this? Thanks in advance.
    May 3, 2012
    1,401
    01:50 PM
    This is a new feature in 2014 isnt it? Is there a new Family Template for this kind of air terminal?
    I guess new air terminals for this should be made from the Autodesk ones then..
    Member TFuller's Avatar
    March 7, 2014
    Evansville, IN
    361
    06:50 AM
    I also found once that moving the duct did strange things to the air terminal locations.
    September 19, 2017
    Seattle, WA
    37
    04:50 AM
    I have experienced similar issues with duct-mounted air terminals. In regards to air terminals moving when the duct moves, I found that the connector didn't like being anywhere but the exact center of the family, and Revit generated a warning saying as much. I was able to finagle with it in my original family and did manage to flex the connector acceptably. When recreating the family recently, I got around this problem by modelling the mitered can in a separate family and nesting it in, which, on the whole, made the family a lot simpler. FWIW, the terminal still connects to the ductwork on the Left/Right origin plane, not where the connector is.
    But then I ran into Tannar's original problem when I went to modify the family in a project. After a little bit of testing, I feel confident in saying that, in my case, having the vertical justification of the host ductwork set to top or bottom instead of middle was the source of the problem. Fortunately, if you justify the ductwork and then manually change the justification back to middle in the properties window, the air terminals work as expected and the ductwork stays in the correct spot.
    Sorry for necroposting, this seemed like a worthy instance if anyone else had similar issues.
  1. Issues with duct lining
    By jcorbymyers in forum MEP - General
    Last Post: November 25th, 2015, 04:34 AM
  2. Air Terminal on Duct and Groups
    By TFuller in forum MEP - General
    Last Post: June 6th, 2014, 09:56 AM
  3. Replies: 6
    Last Post: November 15th, 2013, 02:27 PM
  4. Air Terminal Numbers
    By domsib in forum Architecture and General Revit Questions
    Last Post: August 21st, 2012, 01:18 PM
  5. Duct and Terminal Connection
    By MeSoNaM in forum MEP - General
    Last Post: August 11th, 2012, 03:28 PM
