Results 1 to 2 of 2
Thread: Pipe are far form connectors
    November 12, 2012
    Bangalore
    39
    09:03 PM
    Hi Friends
    I am not able to Figure Out what is Causing this Issue.
    I have Created a Gully Family which has a Pipe Connector in the Bottom Part of Gully where when I Load it into a project and create a pipe in a elevation view the pipe is created but far from gully as you can see in attached image.
    I am not able to Determine what is the Issue Help me.
    Attached Thumbnails Attached Thumbnails Pipe are far form connectors-gully.jpg
    May 3, 2012
    1,403
    05:33 PM
    does it only do this in elevations? You need to select the gulley, right click on the connector + and do draw pipe to start in the right plane. Otherwise pipes drawn in elevation/section are drawn in the location of the the section view line/plane.
  1. Pipe Settings dialog vs Pipe Systems
    By Ch2M_MikeMaloney in forum MEP - General
    Last Post: December 7th, 2015, 08:00 PM
  2. Square/Rectangular Pipe: Is there a System Pipe this shape?
    By samz1 in forum Architecture and General Revit Questions
    Last Post: March 5th, 2014, 11:22 PM
  3. Families connectors to pipes
    By domsib in forum MEP - General
    Last Post: March 26th, 2013, 01:00 PM
  4. Move Pipe Connectors in family
    By domsib in forum Architecture - Family Creation
    Last Post: March 18th, 2013, 10:35 AM
  5. Pipe Connectors move........
    Last Post: October 3rd, 2012, 09:20 AM
