Results 1 to 4 of 4
Thread: Track Lighting
    Senior Member
    November 27, 2012
    599
    06:12 AM
    Track Lighting
    Anyone got an experience with track lighting, know of where to download some files from.
    or How to go about creating it, I have never really created any lighing families as of yet
    Cheers
    December 21, 2010
    C.LONDON
    4,396
    06:12 AM
    Line-based GM template is a good place to start - I tend to build the track as native geometry, then array shared nested families - but if it's non-linear, (i.e. a curvy track) you'll need to either get up to speed on adaptive components or (and this will get me shot by some) you could always repurpose a baluster template (for the light fixtures) and use a railing (for the track)!
    EDIT But these are for architectural-use, where we don't do all the natty-MEP connector stuff, so I don't know how that will play with your needs.
    Senior Member PijPiwo's Avatar
    May 20, 2011
    Chicago, IL
    788
    12:12 AM
    Halo has a huge library Revit Files
    And some other resources:
    Autodesk Seek: track light
    Revit Architecture 2010 User's Guide
    Senior Member ekkonap's Avatar
    May 23, 2011
    Netherlands
    587
    07:12 AM
    EDIT But these are for architectural-use, where we don't do all the natty-MEP connector stuff, so I don't know how that will play with your needs.[/QUOTE]
    Easy, just select the nested families when you're done (having made sure they are hosted on the placement level in the baluster) and copy-paste, switch the nested one off with a visibility parameter. Once independently hosted in the project, the connectors become available for MEP. The railing rig is basically a placement tool with more flexibility than an array.
    Nested connectors could do with some improvement though.
  1. Way to track which views have which scope box assigned?
    By aperte in forum Architecture and General Revit Questions
    Last Post: October 17th, 2016, 08:43 PM
  2. Replies: 5
    Last Post: May 20th, 2013, 01:24 PM
  3. Does Revit keep track of work time
    Last Post: March 19th, 2012, 08:24 PM
  4. Modeling a rail car track down the side of a mountain.
    By petergiampaoli in forum Architecture and General Revit Questions
    Last Post: May 2nd, 2011, 04:48 PM
