Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By josephpeel
Thread: How to keep round duct flat on top - eccentric taper
    Senior Member
    November 27, 2012
    599
    08:17 PM
    What is the best practice to keep round duct flat to the top so to speak.
    with rectangle duct I just align the 2 ducts then drag the other to it and it gives me and eccentric transition, but with round I can only align to the center line..
    N
    March 20, 2012
    Austin, Texas
    224
    02:17 PM
    Quote Originally Posted by nick_h View Post
    N
    When you're aligning your round ducts, press tab to select the outer edge of the duct, then align and reattach the duct.
    Member MrBIMtastic's Avatar
    August 2, 2012
    Phoenix, AZ
    151
    12:17 PM
    When drawing the duct, set the Vertical Justification to "Top"
    How to keep round duct flat on top - eccentric taper-justification.pngHow to keep round duct flat on top - eccentric taper-top.png
    Senior Member
    November 27, 2012
    599
    08:17 PM
    STILL! Having problems with eccentric tapers they are becoming a pain in the A** why cant they just stay flat on botton or top, and equal to each side
    **im Moddling the duct coming off a AHU reducing in size, setting the just' to centrel and bottom and its coming off equall even though its eccentric taper
    Headbanging!
    August 2, 2012
    Phoenix, AZ
    151
    12:17 PM
    When I'm working to tight constraints (like coming off an AHU) I'll draw the duct coming off the connection out maybe 10'. Then change size and draw another 10'. Now I can select the reducing fitting and drag/nudge it back till it's the minimum distance from the AHU connection (if that's the desired config.) If things still aren't behaving, Align and Trim are your friend. Align the center lines in plan (just to be sure.) Now align the bottom (or top) in a section. Tab while hovering over the edge to select that elusive bottom surface. Now Trim. Once it's aligned in two planes, I've never had it not connect. Just make sure your ducts are long enough to be eaten up by the fitting. You can move the fitting after.
    Senior Member
    November 27, 2012
    599
    08:17 PM
    cheers for that, it helps..
    another question, how do you put a offsett taper in so that i dont have to use 2 bends and straigh piece to drop 200mm or so (my engineers just moaned saying they wouldn't do that on site etc.. ) (ive just drawn the second one in to show what i need)
    How to keep round duct flat on top - eccentric taper-duct1.jpgHow to keep round duct flat on top - eccentric taper-duct2.jpg
    August 2, 2012
    Phoenix, AZ
    151
    12:17 PM
    I'm not sure about that one. I'm not sure there is even a fitting type that can accommodate that in Revit. I'll take a look though. Anyone else have ideas about that?
    Senior Member
    November 27, 2012
    599
    08:17 PM
    Quote Originally Posted by MrBIMtastic View Post
    Think its just an eccentric taper, ive seen it drawn by mistake but how you get one when needed, i dont know
    May 3, 2012
    1,403
    09:17 PM
    There is a revit duct fitting category called Offset that works exactly like your second drawing. Unlike a union or transition, that have one duct centre line and are controlled by the Justification, The offset category can have two duct centrelines for the in and out connections. So the vertical and horizontal offset between the two connectors can be set to whatever you like and it reliably stays that way. You can use them to make eccentric transitions with flat top/bottom too using a bit of trigonometry. Try using an OOTB "Offset" duct fitting or family template to make what you want. The only disadvantage of the offset category is you cant use it in the routing preferences, so its something you need to place manually each time.
    MrBIMtastic likes this.
  1. Flex duct keeps connecting to top of duct
    By Npstewart in forum MEP - General
    Last Post: January 10th, 2017, 05:22 AM
  2. Flat roof drainage - crickets around a parapet
    Last Post: February 5th, 2016, 04:26 PM
  3. Flat Pad on Sloped Roof
    By B Arch in forum Architecture and General Revit Questions
    Last Post: November 23rd, 2015, 09:36 PM
  4. Flat on Top Transition
    By aykhan9 in forum MEP - General
    Last Post: August 19th, 2014, 01:51 PM
  5. Flat roof with tapered insulation
    By need4mospd in forum Architecture and General Revit Questions
    Last Post: June 20th, 2014, 02:02 PM
