Results 1 to 3 of 3
Thread: MEP hidden lines
    December 3, 2012
    6
    05:08 PM
    MEP hidden lines
    What adjustments do I need to so the elbow and line work of the 6x4 run of duct shows up "hidden" under the 36x18 duct that is turning up? It shows if I turn on wire-frame and appears correct in section. (see attached)
    January 17, 2011
    2,049
    04:08 PM
    Try hiding the Fitting or the Duct - one of the two - in the Plan View.
    December 3, 2012
    6
    05:08 PM
    I can make adjustments so that the elbow shows as hidden, but what about the "partial run of 6x4 duct" coming down from the top of the view (see wire frame layout)? MEP hidden lines-duct-view-question.jpg
  1. Hidden line view. Hidden lines showing.
    By redmonki in forum Architecture and General Revit Questions
    Last Post: July 27th, 2013, 09:12 AM
  2. Draw MEP Hidden Lines on & off in same project?
    By tzframpton in forum MEP - General
    Last Post: May 1st, 2013, 07:40 PM
  3. Show hidden lines - need help
    By Hilife in forum Architecture and General Revit Questions
    Last Post: December 7th, 2012, 01:12 PM
  4. Hidden Lines Through Interior Partitions
    By Alexander_J_Hicks in forum Structure - General Questions
    Last Post: September 18th, 2012, 12:37 PM
  5. Hidden Lines - Structural Foundations
    By DD1 in forum Structure - General Questions
    Last Post: June 13th, 2012, 12:10 PM
Tags for this Thread
