Results 1 to 4 of 4
Thread: Pipe and duct fittings not part of systems
    April 12, 2013
    45
    01:56 AM
    Weird. Anyone experienced this problem before?
    March 20, 2012
    Austin, Texas
    224
    08:56 PM
    Quote Originally Posted by JamesLawrence View Post
    Are they actually not part of the system or is there maybe a filter applied that isn't set to apply to pipe fittings? If they're not part of the system, I would check the pipe connectors in your fitting families and make sure they're set to "Fitting".
    April 12, 2013
    45
    01:56 AM
    Nope. All filters are spot on, thing is I have drawn ductwork fine in the same project. All problems I have had stem from the new Architects model. Completely stumped
    March 20, 2012
    Austin, Texas
    224
    08:56 PM
    Hmm. Just a stab in the dark, but is this on a different floor of the model? Sometimes the Underlay will be set by default to the floor below and it will cause pipe and duct fittings to display weird. Setting the Underlay to none will fix it if that is the case.
  1. Pipe Settings dialog vs Pipe Systems
    By Ch2M_MikeMaloney in forum MEP - General
    Last Post: December 7th, 2015, 09:00 PM
  2. Pipe Fittings
    By MWatts12 in forum MEP - General
    Last Post: August 22nd, 2013, 03:31 PM
  3. Revit Pipe / Duct Fittings to NWC Shifted Randomly
    By jbr12 in forum MEP - General
    Last Post: February 1st, 2013, 01:17 PM
  4. Duct Fittings Appear Ligther in Plan View
    By bgodava in forum MEP - General
    Last Post: June 12th, 2012, 04:06 PM
  5. Inside the System: TIP: Creating Pipe/Duct Fittings in Revit MEP
    By Inside the System in forum Blog Feeds
    Last Post: August 9th, 2011, 08:40 AM
