Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Display issues in MEP!!
  1. #21
    Mr. Revit OpEd
    2,392
    12:40 AM
    Just a shot....is your inactive worksets set to gray?
    Was about to write... is the Active Workset for the view "closed".
    If it is just the one view it is possible that it has become "corrupt". What happens if you make a brand new view of the level and match the settings?
  2. #22
    Member ThatBIMGuy's Avatar
    May 23, 2011
    Denver, CO
    456
    02:40 AM
    Quote Originally Posted by Steve_Stafford View Post
    well the clues you've offered so far suggest phasing is a least involved... more clues?
    What else can I offer?
    Nope, unchecked and no worksets are turned off.
    How the hell does that happen? Because I created a new view and everything looks good! WTH!
  3. #23
    JBZ
    JBZ is offline
    Senior Member JBZ's Avatar
    December 17, 2010
    Los Angeles
    670
    01:40 AM
    ...if it is just the one view it is possible that it has become "corrupt". What happens if you make a brand new view of the level and match the settings?
    Quote Originally Posted by BCERBIMMan View Post
    ...How the hell does that happen? Because I created a new view and everything looks good! WTH!
    It IS on a computer right? That's how!!!
    It could be Revit, it could also be impossibly numerous 'other' things corrupting the data.
  4. #24
    Member DMapes's Avatar
    February 10, 2011
    Kansas City, Missouri
    100
    08:40 AM
    I have seen this issue. It only happens when I have my plumbing view with an overlay. Try changing the overlay for the view to "none". I would also try checking that the same look up tables are being referenced. Hope this helps...
  5. #25
    May 23, 2011
    Denver, CO
    456
    02:40 AM
    Quote Originally Posted by DMapes View Post
    Like I said in the original post, Im having a brain fart. So it didn't even dawn on me to check the underlay. Ive been messing with this thing off and on all day. Sure enough, I look at the properties. Underlay is set to Level 1 (itself), switched it to NONE and boom. Everything looks good!
    Thanks for all the help and patience today! Im going to go and now.
  6. #26
    Coeur d Alene, ID
    4,175
    12:40 AM
    Almost :30 right?
  7. #27
    May 23, 2011
    Denver, CO
    456
    02:40 AM
    Almost :30 right?
    Its pool league night for me, so in about 2.5 hours yes!
  8. #28
    Mr. Revit OpEd
    2,392
    12:40 AM
    Thanks DMapes!
    I can reproduce the issue by changing the underlay to the same level as the fittings are associated with. Doesn't seem to mind other levels as an underlay. It affect duct fittings too if the view is set to coarse. Definitely quirky.
    As for a "corrupt" view, in this case the new view wasn't using an underlay so no issue. That made it look like the other one was corrupt when it really was what DMapes described. Creating a new view at least helps focus on view settings. As for more clues (not necessary now though), a screen shot of the the two views properties side by side would have helped track down differences.
  9. #29
    February 10, 2011
    100
    08:40 AM
    Glad I could help.
  1. Possible display issues in 2013
    By Madelien in forum Architecture and General Revit Questions
    Last Post: February 25th, 2013, 02:47 PM
  2. Display
    By wannabekahn in forum Architecture and General Revit Questions
    Last Post: January 11th, 2013, 02:42 PM
  3. Display Error
    By Anncan in forum Architecture and General Revit Questions
    Last Post: July 26th, 2012, 11:09 PM
  4. Worksharing Display
    By DaveP in forum Architecture and General Revit Questions
    Last Post: February 9th, 2012, 02:01 PM
  5. Display Problem
    By Alex Cunningham in forum Hardware and Infrastructure
    Last Post: February 2nd, 2011, 05:21 PM
