Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By Aaronb
Thread: Pipe types
    Senior Member
    November 27, 2012
    577
    10:54 PM
    Pipe types
    How do you load pipe types (stainless, cast iron, etc.. ) i only seem to be able to use copper and im not sure how to change, ive tried loading the family but cant seem to find it.
    not sure what im doing wrong
    cheers
    March 20, 2012
    Austin, Texas
    224
    05:54 PM
    Quote Originally Posted by nick_h View Post
    cheers
    To create a new pipe type, just duplicate a built-in type, then go to Routing Preferences and change your pipe material there. If you need to add a pipe material, go to Mechanical Settings, then Segments and Sizes.
    anthonyB likes this.
    Member ThatBIMGuy's Avatar
    May 23, 2011
    Denver, CO
    461
    03:54 PM
    You actually have to create them or download them from somewhere like Charlotte Pipe. Under the Pipe Settings of the MEP Settings, there are pipe segments already created which you would use in the pipe routing preferences of the new pipe types created. When it comes to downloading from Charlotte, keep in mind, you should download the fittings and place the lookout tables that come with them in your lookouttable folder. Preferably a network location. Hope that helps.
  1. Pipe Fitting Connections to each other/NO Pipe
    By se13gits in forum MEP - General
    Last Post: July 8th, 2016, 01:56 PM
  2. Pipe Settings dialog vs Pipe Systems
    By Ch2M_MikeMaloney in forum MEP - General
    Last Post: December 7th, 2015, 09:00 PM
  3. Wall types
    By Lightofheaven in forum Architecture and General Revit Questions
    Last Post: December 10th, 2012, 03:52 AM
  4. Pipe outlets?
    By lukewallace1990 in forum MEP - General
    Last Post: December 7th, 2012, 02:43 PM
  5. Wall Types
    By Nate L. in forum Architecture and General Revit Questions
    Last Post: September 27th, 2011, 09:45 PM
