Results 1 to 5 of 5
Thread: Revit Pipe / Duct Fittings to NWC Shifted Randomly
    January 23, 2012
    32
    09:57 PM
    Angry Revit Pipe / Duct Fittings to NWC Shifted Randomly
    Running into a problem when exporting NWCs from Revit 2013.
    Pipe and Duct Fittings are randomly shifted every time the NWCs are created. Some fittings are fine, others are not. Next export, different fittings are messed up.
    DWFs export just fine out of Revit.
    Attached Thumbnails Attached Thumbnails Revit Pipe / Duct Fittings to NWC Shifted Randomly-pipe_fittings.png
    January 23, 2012
    32
    09:57 PM
    The above shots are Revit model left, Navisworks NWC file right. Attached is a view of the Navisworks Export Settings inside of Revit
    Revit Pipe / Duct Fittings to NWC Shifted Randomly-nvwks-exp-settings.png
    Member hypnox1's Avatar
    December 9, 2010
    The Mothership
    170
    08:57 PM
    Quote Originally Posted by jbr12 View Post
    Try using inches instead of feet for your model properties on export.
    Also, if you aren't using it, you should use hard clashes that have to be turned on through the navis settings. Link below:
    Autodesk - Autodesk Navisworks Services & Support - Why do I sometime get inaccurate Clash Test distances
    January 23, 2012
    32
    09:57 PM
    I will give the inches a try and see if it makes a difference. Someone replied on twitter that they had a similar issue with the out of the box family fittings. They remade the fittings from scratch and everything worked fine moving forward.
    Already doing hard clashes
    Thanks for the reply!
    December 9, 2010
    The Mothership
    170
    08:57 PM
    Hmm, guess the custom fitting library explains why I haven't seen this problem yet. I didn't like how any of the Revit OOTB fittings operated, especially the DTL families, and ended up building from scratch with the control style I wanted.
    Good to know you are already using hard clashes. It really helps with coordination and it's the goofiest thing that it's not a default option.
  1. Steel pipe and fittings
    By tzframpton in forum MEP - Family Creation
    Last Post: July 16th, 2014, 12:31 PM
  2. Pipe Fittings
    By MWatts12 in forum MEP - General
    Last Post: August 22nd, 2013, 03:31 PM
  3. Pipe Fittings Missed Out When Exporting to Navisworks
    By Ye Zaw Lin in forum MEP - General
    Last Post: October 31st, 2012, 01:58 PM
  4. Duct Fittings Appear Ligther in Plan View
    By bgodava in forum MEP - General
    Last Post: June 12th, 2012, 04:06 PM
  5. Inside the System: TIP: Creating Pipe/Duct Fittings in Revit MEP
    By Inside the System in forum Blog Feeds
    Last Post: August 9th, 2011, 08:40 AM
