Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Like Tree1Likes
Thread: Pipe Settings dialog vs Pipe Systems
    July 12, 2012
    Gastonia, NC
    17
    11:59 PM
    Attached is a Screen shot of my Mech Pipe Teams' Piping Systems and the Pipe Settings dialog. I show this to point out that we are not seeing the new Piping systems in the Settings Dialogue....only the Default Systems. My guys want to setup 'presets' for the various systems for Pipe Types (Materials) based on the Design Sizes, i.e., for a prticular system, the pipe size for a system is between 1/2" and 2-1/2" dia, then they would preset to use say Copper.............anything over that 2-1/2" we would have a system type using Blck Pipe..............etc. BUT since we only see Default Systems in the Settings box, we can't seem to accomplish ths. So the question begs, have we missed something here, of assumed oto much out of her?
    Mike
    Attached Thumbnails Attached Thumbnails Pipe Settings dialog vs Pipe Systems-mech-settings-pipe-vs-pipe-systems-created.jpg
    March 20, 2012
    Austin, Texas
    224
    11:59 PM
    Every new piping system you make is based off of one of those default pipe systems. Notice how all of my pipe systems in the screenshot have a symbol next to them - those represent the default system they were based off of. So my hot Oil system is classified as "Other". What are you guys trying to do with the pipe settings and these new systems?
    July 12, 2012
    Gastonia, NC
    17
    11:59 PM
    Aaron,
    We/they are wanting to set defaults' for the various systems they created......since the "stock' Hydronic Supply is at 9'0" (US) Elev default, They wanted a Chilled Water Supply-Copper, BASED on a stock Hydronic to be created, may be 12'0".....AND for copper sizes UP TO 2" only,,,,,,,,,, then Chilled Water Supply-CSBW50 (CarbonStell-Butt Weld, Sched 50) for 2-1/2" and up at 12'0"......but as you can see in the settings pulldown, we only see the "Stock" systems, not our new additional ones also. And this would set up the same for the other NON-STOCK Systems.
    Does that make sense?
    Mike
    March 20, 2012
    Austin, Texas
    224
    11:59 PM
    Sure, makes sense to me, but unfortunately not to Revit. I don't think any additional Pipe Systems will show up in the pipe settings other than the default ones.
    July 12, 2012
    Gastonia, NC
    17
    11:59 PM
    SOOOOOOOO Close, yet so far away............This really needs to be added as a function..I need to find the wish list again and add this to it.
    Thanks,
    Mike
    Member ThatBIMGuy's Avatar
    May 23, 2011
    Denver, CO
    461
    10:59 PM
    Quote Originally Posted by Ch2M_MikeMaloney View Post
    Mike
    Mike,
    You can achieve this by specifying a new pipe type under families --> Pipe --> Pipe Type. Because of the new routing preferences under the type properties of the pipe type, copper and CS can be used for specific pipe sizes. In previous version, I just named my pipe types as Copper or PVC. In 2013, I will be naming the pipe types based on the system, Hydronic, Domestic Water, PVC, etc. utilizing the new routing preferences. See attached image for a screenshot of the defaults in the OOTB revit templates.
    Hope that helps.
    Member Barrie's Avatar
    August 3, 2011
    Kent, UK
    217
    05:59 AM
    Quote Originally Posted by BCERBIMMan View Post
    Mike,
    Hope that helps.
    I am architectural but I am creating standards for rainwater and drainage plus our M&E group are just starting out in Revit so I am looking to understand MEP.
    I am looking to use sanitry for RWPs since they connect into drainage and foul on a combined system. You suggest pipe types based on use so I would create a RWP type with associated connections, right? So would you create a system type to match (duplicated from sanitry) or just assign the RWP pipes to default Sanitry?
    Also, what does vent get used for? Do the different default Piping Systems behave differently (on calcs etc.) or are they purely organisational?
    Thanks
    May 23, 2011
    Denver, CO
    461
    10:59 PM
    Quote Originally Posted by Barrie View Post
    Thanks
    For the Rain Water, I would duplicate it from the Sanitary system so that is using the Sanitary System Classification. Are you using 2012 or 2013? If you are using 2013, you can specify routing preferences for different sized pipe, so I would create something like what I have in the attachment. If using 12, you make the pipe types based on how I have it listed above.
    Attached Thumbnails Attached Thumbnails Pipe Settings dialog vs Pipe Systems-pipetypes.jpg
    August 3, 2011
    Kent, UK
    217
    05:59 AM
    Thanks for your reply. I am using 2013. So Segments & Sizes are by product, Pipe Types by application and Piping Systems by discreet networks? Just trying to break it down into a logical approach.
    What does Vent get used for or what does it mean to you? Not sure if it makes more sense in US but our guys say they only use vent in combination with soil i.e. SVP so that would be sanitary anyway.
    Do you know if the different default Piping Systems behave differently (on calcs etc.)
    May 23, 2011
    Denver, CO
    461
    10:59 PM
    Yes you are correct, that's how I have 2013 setup for pipe. Vent is used to "vent" the gases from sanitary sewer through the roof of a building. We display vent differently and vent uses different fittings compared to a standard sanitary line.
    The default systems classifications should behave differently but our plumbing guys don't use revit for calcs.
    Barrie likes this.
  1. Down Pipe Creation
    By Scott_CJDH in forum Architecture - Family Creation
    Last Post: October 28th, 2016, 03:54 AM
  2. Pipe Fitting Connections to each other/NO Pipe
    By se13gits in forum MEP - General
    Last Post: July 8th, 2016, 01:56 PM
  3. Pipe Fittings
    By MWatts12 in forum MEP - General
    Last Post: August 22nd, 2013, 03:31 PM
  4. Pipe Inset Tag
    By Mattmoot in forum MEP - General
    Last Post: November 27th, 2011, 10:53 PM
  5. Pipe Family
    Last Post: November 22nd, 2011, 04:58 PM
