Results 1 to 3 of 3
Thread: Pipe fittings with voids
    Member evan.dodds's Avatar
    December 29, 2014
    Calgary, Canada
    196
    04:55 PM
    I'm currently revisiting some of my (copper) pipe fittings to include sockets. Most of the pre-existing fittings that I'm adapting from use voids to model the socket. I've figured that having these voids would be needlessly resource-heavy, so I've deleted them (to just have a solid extrusion represent the socket). However, now I'm thinking (slightly worried) that having the fitting geometry intersect with the pipe geometry might cause some issues. Does anyone have any experience with this or know if the intersecting geometry might cause issues?
    May 3, 2012
    1,401
    12:55 AM
    Intersecting fitting and pipe geometry doesnt cause any problems as far as I know, but if you want correct pipe lengths you should put the connector where the bottom of the socket would be, even if you havent modelled the hole. If the connector is on the outside face of the socket extrusion then the pipe stops there without the bit inserted into the fiting.
    Might not matter but it all adds up in a project if you want to get a total length.
    December 29, 2014
    Calgary, Canada
    196
    04:55 PM
    I have the connectors at the bottom of the socket (that would be weird if you didn't...), I just don't want to have to account for the inside diameter of the cup if I don't have to. But Revit is sometimes anal about things intersecting
  1. pipe fittings and pipe valves size adjustment
    By Darius in forum Dynamo BIM
    Last Post: May 20th, 2016, 01:19 PM
  2. Sanitary Pipe Fittings
    By fifthtexas in forum MEP - General
    Last Post: October 23rd, 2015, 05:50 PM
  3. Pipe fittings not updating
    By JPREng in forum MEP - General
    Last Post: July 9th, 2015, 03:36 PM
  4. Reducing Pipe Fittings
    By kchenault in forum MEP - Family Creation
    Last Post: February 11th, 2015, 01:51 PM
  5. Pipe Fittings
    By MWatts12 in forum MEP - General
    Last Post: August 22nd, 2013, 03:31 PM
