Results 1 to 5 of 5
Thread: SYMBOL NEEDED - Point of Connection / Point of Disconnection
    June 16, 2015
    Reno, NV
    28
    09:15 PM
    Question SYMBOL NEEDED - Point of Connection / Point of Disconnection
    Simple & common annotation. Yet Revit does not have these? I'm pretty sure I am not the first to seek this out. Currently I just have some drafting lines to represent this but it is not ideal. If anyone has any info it would be much appreciated.
    (see image)
    Attached Thumbnails Attached Thumbnails SYMBOL NEEDED - Point of Connection / Point of Disconnection-drawing1-model.jpg
    June 16, 2015
    Reno, NV
    28
    09:15 PM
    Solved.
    Just created a couple of generic annotations and adjusted the DOT arrow head down to 1/32" so it plots okay.
    It would be nice if I could have 1 symbol with both connect/disconnect options (like my cad version of the symbol) but I know I can't have everything.
    10,205
    11:15 PM
    Quote Originally Posted by erratic View Post
    Solved.
    Entirely possible. You just need to make the symbol have two types, with different visibility options.
    February 22, 2013
    333
    12:15 AM
    That's exactly what I do. I try to use this approach as much as possible: fewer families with more types. For example, my Pipe Tag family has 18 Types in it.
    September 19, 2017
    Seattle, WA
    43
    09:15 PM
    I took the multiple type approach for some tags, but having a type for every conceivable combination of information I want (especially with mechanical equipment) just bogged down my types list. The fact that toggling the visibility of lines does not change the snap point of the leader really irritated me when making my first round of tags. For my current project, I ended up creating a tag where each type is one parameter, and I can tag the equipment as many times as I need to to get the right information, and then I just arrange it in the proper format. As an added benefit, I can have the leader connect to the symbol portion of the composite "tag" and not the middle. IMO, much more flexible, but YMMV.
    For a symbol like this though, easy.
  1. Cleanup a multi-point connection?
    By ryntau in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: March 18th, 2018, 04:52 PM
  2. Survey Point in Gau▀ KrŘger coordinate system - project base point (0,0,0)
    By LisaTUWien in forum Structure - General Questions
    Last Post: December 18th, 2017, 03:04 PM
  3. Replies: 4
    Last Post: February 20th, 2017, 11:14 AM
  4. Project Base Point | Survey Point | Absolute Elevation Issue
    By siqbal16 in forum Structure - General Questions
    Last Post: March 29th, 2016, 10:16 PM
  5. Add new control point to existing spline through points? - Not a hosted point
    By tjgreatrex in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: April 7th, 2013, 02:56 PM
Tags for this Thread
