Results 1 to 8 of 8
Thread: Lines, Filled Region, and masks in tags changing insertion point
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    220
    07:36 AM
    I'm having an issue with insertion points of pipe tags. Our tag has an arrow built into it and when I added it to the family the tag trys to insert on either corner of the arrow. Is there a way to correct this behavior? Everything is set to not a reference.
    Attached Thumbnails Attached Thumbnails Lines, Filled Region, and masks in tags changing insertion point-pipe-tag-arrow-01.png
    April 30, 2015
    Michigan
    220
    07:36 AM
    Anyone have any ideas on this? It's been a while.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,124
    07:36 AM
    can you post the family?
    April 30, 2015
    Michigan
    220
    07:36 AM
    Well, that would have been a good start, wouldn't it. Sorry. Here it is.
    Attached Files Attached Files
    December 21, 2010
    Phoenix, AZ
    2,583
    04:36 AM
    My guess, without looking at the file. Is that there is something in the tag that puts the vertical extents of the tag uncentered over the horizontal reference plane.
    May 3, 2012
    1,401
    01:36 PM
    Ive seen the same problem before and it appears the origin of a tag is not affected by the 'Defines Origin' workplanes or the extents. The insertion point is the internal 0,0 origin of the tag family...which you cant see.
    If someone has moved the origin lines in the family they will no longer be on 0,0 and the tag will be inserted offset from the tagged object.
    You could try loading a dwg with a line at 0,0 into the tag family as a reference. Otherwise just move and reload until you get everything centred.
    April 30, 2015
    Michigan
    220
    07:36 AM
    Quote Originally Posted by josephpeel View Post
    That sounds like it would cause a tag to always be offset by the same amount and in the same direction. In the image above you can see that the same tag on the return pipe is in two different positions that appear to be locking to the corners of the arrows.
    December 29, 2014
    Calgary, Canada
    186
    05:36 AM
    I think the arrow get a bounding box placed around it and this becomes the reference that the tag tries to place itself at. If you move the contents of the tag so that the reference line is touching the top or bottom of your arrow(s) then you can have the tag place correctly on the pipe (or duct) without affecting how the non-arrow type of tag places. Just don't do this in the middle of a project otherwise you have to fix all of your tags....
    I remade our tags from being off-centre to centred on the reference plane, but since I usually change the tag types after I place them I didn't feel like I needed to change them back to how they were before. Perhaps I will now...
  1. Insertion Point
    By deepu in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: January 30th, 2018, 09:10 AM
  2. Insertion point
    By deepu in forum Architecture and General Revit Questions
    Last Post: January 13th, 2018, 04:25 AM
  3. Insertion Point
    By deepu in forum Architecture - Family Creation
    Last Post: January 11th, 2018, 08:19 AM
  4. How to make lines visible over mask or filled region?
    By bonzi in forum Architecture - Family Creation
    Last Post: January 17th, 2017, 02:58 PM
  5. Replies: 0
    Last Post: August 17th, 2011, 10:20 AM
