Results 1 to 9 of 9
Thread: Quadrant Profile.
    December 15, 2014
    42
    07:57 AM
    Quadrant Profile.
    Hi All,
    Need some help in preparing this parametric family as given in the image.
    I have extruded a quadrant however the profile is not exactly as the radial bend (150 dia pipe).
    My requirement was the quadrant on the pedestal is supporting a pipe from the level below.
    Thanks for your time in advance.
    Senior Member
    June 14, 2011
    CT, USA
    572
    03:57 AM
    How did you determine the radius of the support?
    December 15, 2014
    42
    07:57 AM
    Quote Originally Posted by RobDraw View Post
    The radius of elbow drives the radius of the quadrant support.
    Senior Member
    June 14, 2011
    CT, USA
    572
    03:57 AM
    If you are using the center line radius that is too small. It should be the outside radius.
    December 15, 2014
    42
    07:57 AM
    Yup that's correct, the elbow is supported from outside.
    Senior Member
    June 14, 2011
    CT, USA
    572
    03:57 AM
    Please verify that is what you are doing or if you need help doing that.
    December 15, 2014
    42
    07:57 AM
    The image that I have attached is a section view. The quadrant on the pedestal is supporting the elbow from outside and matches the same profile as of the elbow.
    Acts like a bed and supports the pipe . Hope this helps.
    Senior Member
    June 14, 2011
    CT, USA
    572
    03:57 AM
    Nope. I don't know what the question is.
    Orlando, FL, USA
    3,117
    03:57 AM
    Quote Originally Posted by Shan1512 View Post
    Family 1) Create a profile family, with a parameter for radius. This will be the arc that will serve as a bed to embrace the pipe.
    Family 2) In a generic model family, in an elevation view, create the support above the pedestal as a sweep. Make the path with a radius parameter. Then use the profile that you did in step 1 as the profile for the sweep. The profile's radius parameter should be associated to a parameter in family 2.
    In the project, you should have control over the radius of the profile and the radius of the path of the sweep.
    Attached Thumbnails Attached Thumbnails Quadrant Profile.-2019-02-27_13-54-41.jpg
    Last edited by Alfredo Medina; February 28th, 2019 at 04:09 PM. Reason: added image
  1. Railing "Edit Profile" similar to wall "Edit Profile"?
    By lost again again in forum Architecture and General Revit Questions
    Last Post: October 26th, 2017, 07:05 PM
  2. Profile Sweep, Family type profile parameter
    By spinxy in forum Structure - Family Creation
    Last Post: January 11th, 2016, 05:56 AM
  3. Using a profile parameter to define a sweep profile within a family
    By mattsim in forum Architecture - Family Creation
    Last Post: May 16th, 2013, 04:47 AM
  4. Replies: 4
    Last Post: March 14th, 2013, 02:31 AM
  5. Wall profile edit - where's the profile outline?
    By DDenton in forum Architecture and General Revit Questions
    Last Post: August 8th, 2011, 08:48 PM
