Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By josephpeel
Thread: Algorithm to find size_lookup values from "in-between" parameter values?
    April 10, 2014
    73
    07:59 AM
    I have calculated a required diameter. I need to lookup the next available size of pipe that's greater than the required value. In Excel, I would use VLOOKUP with EXACT set to false. Does anybody have a handy algorithm for use with size_lookup?
    Senior Member ekkonap's Avatar
    May 23, 2011
    Netherlands
    576
    01:59 PM
    Next available? So simply rounding up wont do you any good. You could add extra lines in the table for every whole number between valid values and round up your input value. You could also modify your input value, like: newinput=
    If(originalinput<6,6,if(originalinput<9,9,if(origi nalinput<13,13,17))) where 6,9,13 and 17 are valid lookup values in your table.
    April 10, 2014
    73
    07:59 AM
    ekkonap, you have indeed come up with a better way. I did this:
    IF (AND(C D2 01 > 0, NOT(C D2 01 > 250)),16,IF (AND(C D2 01 > 250, NOT(C D2 01 > 438)),21,IF (AND(C D2 01 > 438,
    ...etc. which enumerates the intervals, but your way reduces the search space each iteration. Thanks!
    May 3, 2012
    1,396
    01:59 PM
    Is this for Fittings?
    Personally I cant stand lookup tables and find using formulas for all sizes to be much more reliable (And formulas should work for any possible size).
    You can use nested IF statements as Ekko suggests, but what also works very well is to calculate all sizes using formulas based on the Nominal Diameter of the pipe (Which will always be one of the standard pipe sizes available in Revit).
    Use a 'Y = aX + b' formula for a straight line and set the a and b constants to fit the standard/manufacturers data.
    This is easy to do in excel, just graph Nominal Diameter against the dimension you want to set and get the constants from a linear regression line.
    (Or use Y = aX^2 + bX + c if a linear relationship between sizes is not accurate enough)
    This way the fitting works for any (new) possible pipe size and is automatically interpolated to fit. If the pipe sizes in the project are correct then the calculated sizes should also be standard dimensions.
    For some sizes the result may be a few millimeters out, but you can use roundup or accept that it is within construction tolerances anyway.
    The constants can be set per type, so it is also possible to make a standard fitting family that sizes correctly for multiple material thicknesses or bend radiuses etc, just by setting different values of a and b for the formulas.
    I find that this makes very robust, reliable families, which can easily be adapted to new pipe types using Edit Type instead of making new families.
    Attached Thumbnails Attached Thumbnails Algorithm to find size_lookup values from &quot;in-between&quot; parameter values?-example-chart.jpg
    ekkonap likes this.
    April 10, 2014
    73
    07:59 AM
    Joseph, not for fittings, but for calculating the pipes
    in several conduit groups
    needed to accommodate the net cross-sectional area of a mix of AV wires of different EMI susceptibilities. Since the wires themselves change from project to project, I have tables of wire type parameters, notably diameter, that can be updated fairly easily. I'm leery about hard-coding values.
    I don't use the Revit conduits - not enough parameters and my discipline isn't responsible to install the pipe, but only to specify some parameters for installation by others. I revisit the idea every few months, though. Thanks for the help.
  1. easy way to "find" (duplicated) view(s) of sheet in project browser
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: October 19th, 2018, 02:05 PM
  2. Imported Categories Named "1" - Cannot purge/delete/find in groups...
    By Jj Mac in forum Architecture and General Revit Questions
    Last Post: April 25th, 2018, 01:29 PM
  3. Replies: 7
    Last Post: June 24th, 2016, 05:38 PM
  4. "Values can vary by group instance" for parameter
    By Rick Moore in forum Architecture and General Revit Questions
    Last Post: May 11th, 2016, 01:41 PM
  5. "Title on Sheet" parameter field" ?
    Last Post: October 17th, 2011, 12:17 AM
