Results 1 to 4 of 4
Thread: Pipe connectors nested family
    August 24, 2017
    4
    01:12 PM
    Good evening,
    I have a problem with a family with nested flanges in it.
    If I put the pipe accessory in the pipe I get the disconnects from the nested flanges. If I put is beside the pipe the don’t appear.
    Another question: how to turn of the big gray square??
    With kind regards,
    Joost
    Verzonden vanaf mijn iPhone met Tapatalk
    Orlando, FL, USA
    3,093
    08:12 AM
    You can nest the flange family into the valve family, but don´t nest it with its own connector. Do a new connector for each flange in the valve family, or use the same connectors in the valve, moved to the outer face of the flanges. Maybe you are nesting the flange with its own connector into the valve?
    That square is weird, and it seems to have 4 connectors. It is visible in plan view but not in elevations. Open the valve family; probably that element is there but hidden?
    The other warnings refer to open ends.
    August 24, 2017
    4
    01:12 PM
    Thank you for your reaction.
    I Always thought thas if you nest a family the connectors of the family you nest wil disappear. The open connectors whitch are 2 by 2 are from the flanges.
    Orlando, FL, USA
    3,093
    08:12 AM
    Yes, nested connectors disappear and are basically useless. That's why I was suggesting to nest the flange families without connectors, and then, if necessary, move the connectors of the valves out towards the outer face of the nested flanges.
  1. Pipe size connectors!!
    By bogaa561 in forum MEP - Family Creation
    Last Post: October 15th, 2018, 08:59 PM
  2. Pipe are far form connectors
    By amarkrish108 in forum MEP - General
    Last Post: April 2nd, 2014, 09:57 AM
  3. Move Pipe Connectors in family
    By domsib in forum Architecture - Family Creation
    Last Post: March 18th, 2013, 10:35 AM
  4. Pipe Connectors move........
    By Ch2M_MikeMaloney in forum MEP - General
    Last Post: October 3rd, 2012, 09:20 AM
  5. Connectors and nested faces
    By Randy_CaS in forum MEP - Family Creation
    Last Post: June 21st, 2011, 03:59 PM
