Results 1 to 2 of 2
Thread: rectangular booted tee (ASHRAE SR5-13)
    July 10, 2018
    1
    01:56 PM
    I'm trying to created a rectangular booted tee (ASHRAESR5-13). When I try to connect a branch to the main and try to get thefitting to auto-place, I get a "The segment is being drawn from the wrongside to connect to the location you indicated."
    The fitting works great if I drop it in and connect ductsindividually, but I would like the auto-routing placement to work.
    Connector directions are correct.
    See the attached image of the problem and the attachedfitting.
    Any ideas?
    Attached Thumbnails Attached Thumbnails rectangular booted tee (ASHRAE SR5-13)-segment-being-drawn-wrong-side-connect-location-you-indicated.jpg
    Attached Files Attached Files
    May 3, 2012
    1,401
    08:56 PM
    The orientation of the T is wrong. If you open an existing standard T you will see that the main duct goes from left to right and the T connection goes to below (Front).
    Most likely Revit is trying to place the T that way around as default, so the connection fails.
    Also, You use Global connectors instead of Fittings? Does that work reliably with auto sizing when added to a duct? (It is a solution to adding pressure drop calculations I guess)
  1. ASHRAE table Settings - None
    By kvusal in forum MEP - General
    Last Post: August 24th, 2018, 09:04 AM
  2. ASHRAE 62.1 VRP Calculation
    By Necro99 in forum Dynamo BIM
    Last Post: July 29th, 2018, 10:40 PM
  3. Ashrae tables
    By Chris.kershaw in forum MEP - General
    Last Post: December 2nd, 2016, 07:03 PM
  4. Ashrae
    By vikvar29 in forum MEP - General
    Last Post: August 1st, 2016, 02:59 PM
  5. Creating an ASHRAE Schedule
    By txelwood in forum MEP - General
    Last Post: April 25th, 2014, 08:47 PM
