Results 1 to 2 of 2
Thread: Single line work not behaving
    December 29, 2014
    Calgary, Canada
    182
    08:40 PM
    I'm trying to make a multipurpose valve that can switch between being straight and angled in the family. Everything works fine except for one thing: the single line line work does not behave, specifically the part that rotates. I kinda forgot about needing the line work until after I'd made all of the geometry, but even starting in a new family, the rotating line just does not want to behave/wants to break everything.
    I don't know if the reference lines are hindering the symbolic lines from working correctly, but everything works fine if I don't have the symbolic lines in.
    Attached Files Attached Files
    December 29, 2014
    Calgary, Canada
    182
    08:40 PM
    Never mind. I figured out that the rotation point was moving for the model line whenever I tried to go from 0° to a bigger angle (but not vice versa), but only when I had drawn the horizontal line segment. In the end I switched my methods so that instead of trying to use an angle parameter to control the rotating part I constrained the end to two reference planes that switch lengths depending if the valve is set to be angled or straight. I guess I should have known to do that from the get go, however it is weird that the reference lines function like expected but the model lines do not.
  1. Double line and single line pipes based on size?
    By Theophilous in forum MEP - General
    Last Post: July 6th, 2018, 05:04 PM
  2. help to display pipe with with only single line
    By trang_chau in forum MEP - Family Creation
    Last Post: April 18th, 2016, 02:13 AM
  3. Single line pipework layout
    By fifthtexas in forum MEP - General
    Last Post: October 16th, 2015, 03:23 PM
  4. single line display issue
    By RStiles in forum MEP - General
    Last Post: July 9th, 2012, 10:54 PM
  5. representation of beams is just single line !!!!!?
    Last Post: January 1st, 2012, 10:10 PM
