Results 1 to 4 of 4
Thread: Pipe size connectors!!
    August 24, 2017
    4
    03:19 AM
    This is my first post here.
    I am making my own version of an excisting family. When i load the family's in a project i can change the connector size of the excisting family. In my family when a click on the connector size i get the value -609.6mm. Does anybody can help?
    With kind regards,
    Joost
    Attached Files Attached Files
    December 29, 2014
    Calgary, Canada
    182
    08:19 PM
    In the project you attached both the tee fittings are working for me and i can freely change all of the connector sizes. the (-)609.6mm is a default value in Revit that gets assigned to connectors (and other things). If you link the connector to a parameter you should no longer get that value when you load the family into a project.
    August 24, 2017
    4
    03:19 AM
    In the properties of the T-piece i can change the sizes and the family changes, when i change it in the connector where is says -609.6mm nothing changes in the family?
    December 29, 2014
    Calgary, Canada
    182
    08:19 PM
    Are you trying to change the value of the connector size through the connector itself, or through a parameter that you've assigned to the connector? I never change the value of the connector through the connector itself.
    Do all of your connectors have parameters assigned to them?
    If you do have a parameter assigned to the connector then your ability to change the value of that connector can only happen by editing the parameter values. The connector by itself has no relation to the rest of the objects in your family. This only happens when you assign a parameter to it (The parameters are what defines the relationships between everything in the family)
  1. pipe fittings and pipe valves size adjustment
    By Darius in forum Dynamo BIM
    Last Post: May 20th, 2016, 01:19 PM
  2. Replies: 2
    Last Post: July 12th, 2014, 06:13 AM
  3. Pipe are far form connectors
    By amarkrish108 in forum MEP - General
    Last Post: April 2nd, 2014, 09:57 AM
  4. Move Pipe Connectors in family
    By domsib in forum Architecture - Family Creation
    Last Post: March 18th, 2013, 10:35 AM
  5. Pipe Connectors move........
    By Ch2M_MikeMaloney in forum MEP - General
    Last Post: October 3rd, 2012, 09:20 AM
Tags for this Thread
