Results 1 to 7 of 7
Thread: Help - Family Creation
    October 5, 2018
    4
    02:10 PM
    Hello everyone. This is my first post on here. With all the knowledge, I am hoping someone can help.
    I have created some revit families but I am now wanting o do something beyond my knowledge level.
    Specifically, I have supply air diffusers which allow you to input the airflow to them.
    Is there any way to make it so that if you enter an air value which exceeds the minimum or maximum CFM listed in the family that I can get the color to change? Typically, my diffusers and grilles are grey. So I would like them to turn bright red or orange if the minimum or maximum CFM is outside the allowable numbers set in the family.
    Thanks very much.
    Nico
    Mr. Revit OpEd
    2,825
    07:10 AM
    Create an extra solid form that only turns on when your criteria is met. Use a separate material to define a warning appearance.
    October 5, 2018
    4
    02:10 PM
    Can I have it only turn on when it is not met? For example one diffuser type is set to 648 cfm max. If you input 700 cfm - which is above, the extra solid would turn on?
    October 5, 2018
    4
    02:10 PM
    This is working well. Thank you Steve. I am having an issue with the color though. The never solid(s) are bright red, but they do not show up like that in my model when I insert the diffuser and test it out. Any idea what I am missing here?
    Gold Coast
    2,502
    12:10 AM
    Quote Originally Posted by RevitNoob1971 View Post
    You probably need to update the object styles in the project. Whatever existing standard you set/change in a family will be overwritten when you load into a project.
    October 5, 2018
    4
    02:10 PM
    Thanks very much!
    February 22, 2013
    315
    10:10 AM
    What I do on all of my families is use conditional formulas (nested if statements) stepping up the duct diameter with each nested "if" statement. For the final "if", when I exceed the maximum air flow of the maximum size, I have the formula set the diameter to 0". This is geometrically impossible and will cause Revit to throw a "Can't make type" error when you overload the diffuser. This way you CAN'T overload the device. I also have a "size override" parameter that will bypass the whole sizing formula if that value is nonzero, which is good for representing existing air devices.
  1. Replies: 9
    Last Post: May 11th, 2012, 06:24 PM
  2. Live Session - Family Creation Series #4 | Family Phasing, Sweeps and Shared Params
    By rkitect in forum Architecture and General Revit Questions
  3. Replies: 16
    Last Post: April 26th, 2012, 09:16 AM
  4. Live Session - Family Creation Series #3 | Family Phasing and Geometry Modeling
    Last Post: April 25th, 2012, 07:03 PM
  5. Live Session - Family Creation Series |#2-Family Planning
    By rkitect in forum Live Sessions - Archive
    Last Post: March 21st, 2012, 09:01 PM
