Results 1 to 4 of 4
Thread: Having Issues moving families Together
    May 14, 2018
    24
    06:53 PM
    So I have a Door and Box which need to go same height and width when the dimensions change
    Example: Cabinet Width= 100 Door Width = 100 - 1.5- 1.5 ( The 1.5 in family works) its just the door doesn't move to the right place where cabinet goes instead of going left it goes right ..hmm what am I doing wrong?
    Check the image for reference.
    Attached Thumbnails Attached Thumbnails Having Issues moving families Together-1.jpg
    July 7, 2011
    Rotterdam, Holland
    1,228
    08:53 PM
    What I always do is build these type of families from the middle, so locking stuff to the center ref plane and having a left and right ref plane that are EQ and with the width parameter.
    Not easy to figure out this stuff from just a few images, but it looks like you build them from the center ref plane to one side and if you have the door mirrored compared to the cabinet, if you change the width they both extend in the other direction and end up in the wrong place. So, I think in this case you can mirror your door and lock it in place again an that should do the trick.
    May 14, 2018
    24
    06:53 PM
    omg - I did that ..(Post file to RFO please) ( to show what I did)
    May 14, 2018
    24
    06:53 PM
    Not sure if mirroring would do it for me , looking at the door I am trying to pin it to the middle and see if the references would - I have a feeling i have to go ahead and fix the families individually ..
  1. Structural model uses door families for structural openings. Major room bound issues
    By Andrew P in forum Architecture and General Revit Questions
    Last Post: February 19th, 2019, 01:10 PM
  2. Moving Section Tag without moving view constraints with it.
    By Trae33 in forum Architecture and General Revit Questions
    Last Post: October 27th, 2017, 02:15 PM
  3. Plan Regions vs. Families Visibility Issues
    By RobDraw in forum Architecture and General Revit Questions
    Last Post: July 28th, 2016, 06:42 PM
  4. Replies: 0
    Last Post: July 28th, 2014, 04:15 PM
  5. Families in Groups not moving Floor to Floor
    By MCleveland in forum Architecture and General Revit Questions
    Last Post: December 21st, 2012, 06:42 PM
Tags for this Thread
