Results 1 to 5 of 5
Thread: Parameters: LoadBearing, IsExternal and FireRating
    Junior Member Bogey1977's Avatar
    July 12, 2018
    Nederland
    29
    04:41 AM
    Parameters mentioned below here, are those parameters for architectual and constructural parties only or also for us MEP folks?
    - LoadBearing
    - IsExternal
    - FireRating
    LoadBearing: do I need to use it for example for foundation underneath mechnical components
    IsExternal: do I need to use it for example for structural openings (recess) in the thermal peel
    FireRating: do I need to use it for example for the fire dampers en recesses
    Gold Coast
    2,621
    01:41 PM
    As far as i'm aware those parameters are typically for filtering data. I see no reason you couldnt use them but id first check that other disciplines arent using them for critical information to avoid overlapping.
    Or you could just use your own custom parameters.
    July 12, 2018
    Nederland
    29
    04:41 AM
    It's not that I want to use those parameters, but more likely DO I NEED to use those parameters?
    The info in those parameters is no info we work with, but thought maybe other parties need this info.
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    320
    05:41 AM
    Depends on how strict the other parties are working with ILS and the possibilities in Navis/Solibri. Not including those parameters in your elements will flag your model as non-compliant in ILS checks.
    Don't forget you can 100% use your own parameters there and map them to the right IFC properties in the export.
    (For other people: ILS is a Dutch protocol for IFC coordination between parties)
    July 12, 2018
    Nederland
    29
    04:41 AM
    Quote Originally Posted by Bjorn_K View Post
    Depends on how strict the other parties are working with ILS and the possibilities in Navis/Solibri. Not including those parameters in your elements will flag your model al non-comliant in ILS checks.
    Thank you Bjorn, I am going to build them in into my families.
  1. Loadbearing under hatches for Australia
    By williem86 in forum Structure - General Questions
    Last Post: August 22nd, 2018, 02:06 PM
  2. Replies: 0
    Last Post: September 15th, 2015, 02:15 PM
  3. Replies: 0
    Last Post: July 13th, 2015, 09:45 AM
  4. Replies: 0
    Last Post: July 10th, 2015, 03:45 PM
  5. Replies: 0
    Last Post: July 2nd, 2015, 09:15 AM
