Results 1 to 8 of 8
Thread: Flang family
    Junior Member Bogey1977's Avatar
    July 12, 2018
    Nederland
    29
    08:36 PM
    Flang family
    Hi all,
    I am going to build a family for flangs. I have a couple questions to point me in the right direction.
    Different sizes flangs have different numbers and sizes of holes. Number and size of holes are in parameters. This parameters I will use for my array to cut out the holes in the flang.
    The questions I have are:
    1.) Is it possible to add a nested family with just a void?
    2.) Can I use this nested family (void) to cut out holes in my flang?
    Answers on those 2 questions will make me getting start.
    Gold Coast
    2,617
    05:36 AM
    Quote Originally Posted by Bogey1977 View Post
    Hi all,
    1. Yes
    2. I don't think so, AFAIK void families will cut in project only. Void needs to be made in same family, not nested. But it's late here and and not at Revit. Someone will say if I'm wrong.
    July 12, 2018
    Nederland
    29
    08:36 PM
    Thank you for your answer...
    I got it clear that it is better to NOT use arrays and NOT use voids in family's. If possible avoid using those things to prevent problems with the model.
    I got it worked around now
    June 21, 2012
    Tours, France
    980
    09:36 PM
    1. Yes
    Actually I have a CHILD void family which I have to cut some parts on my furniture PARENT family, so yes! you can use a CHILD void family to cut some objects, by the way my void family is face based, HTH
    Gold Coast
    2,617
    05:36 AM
    Actually I have a void family which I have to cut some parts on my furniture, so I guess you can use a void family to cut some objects, by the way my void family is face based, HTH
    You have a nested void family that cuts the geometry in the parent family? Maybe FB is the trick!
    June 21, 2012
    Tours, France
    980
    09:36 PM
    Yes i do have a void family that cuts my parent family!! Actually I just wanted to cut some objects in my furniture and I just create that thing to see if it worked and it did!! don't know if the key is the FP but for me that works, regards
    June 21, 2012
    Tours, France
    980
    09:36 PM
    This is my void family (see images) which is intend to cut the PARENT family, so as already said is a FB family with some basic parameters for height and depth, that family was inserted in my Parent family to cut in specific places, so I'm pretty sure that it works like a champ!!
    Attached Thumbnails Attached Thumbnails Flang family-1.jpg   Flang family-2.jpg   Flang family-3.jpg
    September 22, 2018
    1
    07:36 PM
    How u got it worked share ur family here
  1. Replies: 0
    Last Post: December 15th, 2017, 03:45 AM
  2. Replies: 0
    Last Post: March 27th, 2016, 07:18 AM
  3. Replies: 0
    Last Post: February 4th, 2014, 10:45 PM
  4. Replies: 0
    Last Post: September 27th, 2013, 06:45 AM
  5. Can't change family origin point, family loads into project as hidden lines
    By lukewallace1990 in forum Architecture - Family Creation
    Last Post: February 1st, 2013, 03:51 PM
