Results 1 to 3 of 3
Thread: How to create Calculated value formula
    August 14, 2018
    1
    10:35 PM
    Hello all,
    How to create calculated value in Schedules by using Count parameter? I knew that count cannot be used as a fields but any other alternate method is available to proceed further. Please help me in this case.
    Thanks in advance
    December 21, 2010
    Phoenix, AZ
    2,556
    10:05 AM
    You can’t.
    You can work around it by setting a new calculated value to 1, totaling that column, then another calculated value that shows to percentage of the “1” parameter relative to the total/sub-total, and finally one more calculated value that takes the invert of the percentage (1/%) which will give you the total/subtotal in each row.
    That was from memory so I might have missed something... if I remember I’ll share an example later today.
    May 3, 2012
    1,396
    07:05 PM
    There are several threads about a solution to this.
    https://www.revitforum.org/architect...unt-total.html
    (Also known as the "Total Mayhem" solution, so you can search for that too.)
  1. Replies: 2
    Last Post: November 18th, 2016, 02:24 PM
  2. Improper use of Boolean Expression message with my calculated value formula
    By sippel26 in forum Architecture and General Revit Questions
    Last Post: February 13th, 2014, 08:20 PM
  3. Help with my formula in calculated Value
    Last Post: January 29th, 2014, 07:56 PM
  4. Calculated Value
    By ralbanesi in forum Architecture and General Revit Questions
    Last Post: December 13th, 2012, 10:10 PM
  5. Schedule formula (is there a formula expert in the house?)
    By John McCamont in forum Architecture and General Revit Questions
    Last Post: September 9th, 2011, 09:50 PM
