Results 1 to 4 of 4
Thread: Visibility - only one chceck box
    July 10, 2018
    1
    04:32 PM
    Hi all,
    i need help with checking visibility box. I have four instant parameters of visibility and i need always only one box checked.
    Example:
    If i put in family to project, parameter A is checked, B,C,D is unchecked.
    If i checked parameter B, a need to automatic uncheck A.
    If i checked parameter C, a need to automatic uncheck B.
    and so on. Just only one parameter check automately.
    Is it possible to make it by If/than?
    Thank you very much. Lukas
    10,175
    11:32 AM
    Quote Originally Posted by luckyxman View Post
    Hi all,
    Example:
    It's possibly using a fifth parameter called user input, where the user inputs a 1,2,3, or 4. Or using a family type selector parameter.
    Can't do it with just four yes/no parameters.
    Aaron Maller
    Director
    Parallax Team, Inc.
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    11:32 AM
    Meanwhile, go vote up this Revit Idea
    https://forums.autodesk.com/t5/revit.../idi-p/6315262
    in the hopes that eventually this can be built in & we won't need workarounds
    May 3, 2012
    1,401
    06:32 PM
    Its possible... its just a real pain to implement.
    (This is from a AU document called AB327-4 Fuzzy Math Essentials for Revit Family Builders)
    If there are more than two exclusive options (Parameter A = Test, Parameter B = NOT(Test)) then use a Type selector with nested family.
    If you want to set a lot of parameters at the same time with one selection.. that is what Types are for.
    Attached Thumbnails Attached Thumbnails Visibility - only one chceck box-bool.jpg
  1. IF and visibility
    By jair_gh in forum Architecture - Family Creation
    Last Post: September 19th, 2016, 08:33 PM
  2. window visibility
    By mona miller in forum Architecture and General Revit Questions
    Last Post: August 7th, 2013, 03:04 AM
  3. Visibility/Graphics - Workset Visibility Setting
    By safoulkes in forum Architecture and General Revit Questions
    Last Post: July 27th, 2012, 02:49 PM
  4. Visibility bug ?
    By neolopus in forum Architecture and General Revit Questions
    Last Post: May 12th, 2012, 02:13 PM
  5. Visibility
    By Rev Dawg in forum MEP - General
    Last Post: March 22nd, 2012, 08:39 AM
