Results 1 to 4 of 4
Thread: "Circuit Number" Parameter Value?
    July 2, 2012
    3
    01:29 PM
    Can the value contained in the "Circuit Number" parameter be read and compared using a formula for a label? I need to create a label tag for wire color designation. An example of the formula: if(circuit number=1,"red",""). I assume that because the "Circuit Number" parameter is a system parameter that it is not accessible?
    Orlando, FL, USA
    3,088
    04:29 PM
    No, not possible, because "Circuit Number" is a text parameter, therefore it is not possible to use that value as the condition of an IF formula.
    As an alternative, you could do this in a visual way, adding a view filter that finds wires whose circuit number is "1", and then assigning color red to those wires.
    December 21, 2010
    Phoenix, AZ
    2,556
    01:29 PM
    Funny... cause it says "number" --
    February 11, 2019
    3
    01:59 AM
    Actually no, impractical, in light of the fact that "Circuit Number" is a content parameter, subsequently it is preposterous to expect to utilize that esteem as the state of an IF recipe.
    As an option, you could do this outwardly, including a view channel that discovers wires whose circuit number is "1", and after that relegating shading red to those wires.
  1. Add property "Building Number" in Revit Architecture and export to Ifc file
    By RobSSS777 in forum Architecture and General Revit Questions
    Last Post: April 13th, 2016, 01:24 PM
  2. Error "No circuit errors found" when deleting objects
    By alnjxn in forum Architecture and General Revit Questions
    Last Post: August 22nd, 2013, 03:47 PM
  3. Family Shared Parameter "Group Parameter Under" in a Project
    By Aretap in forum Architecture and General Revit Questions
    Last Post: August 10th, 2012, 10:18 PM
  4. "Detail Number" in the View List
    By Joshua Kohl in forum Architecture and General Revit Questions
    Last Post: November 14th, 2011, 02:21 PM
  5. "Title on Sheet" parameter field" ?
    Last Post: October 17th, 2011, 12:17 AM
