Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By josephpeel
Thread: LW
    February 16, 2018
    1
    01:50 PM
    LW
    can a pipe system parameter be included in the pipe schedule field?
    May 3, 2012
    1,401
    08:50 PM
    No. Unfortunately only the standard system parameters that are in the pipe properties.
    Create a separate systems schedule and show all the system details there.
    Because these are the only System parameters available by Pipes and Ducts (and other stuff) I use 'System Name'-Contains-'Unique system code' to filter everything by system.
    The System Name is automatically created (Abbreviation plus number) so if you give every system type a unique abbreviation the system name will also be unique per system type.
    Filtering by System Name (Rather than System Abbreviation or System Type) is the best option because it not only works for pipes, but also with Air Terminals, Plumbing Fixtures, Mechanical equipment etc. Even things with more than one system type connected can be filtered using 'System Name - Contains'
    WelcomeToAccord likes this.
