Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By jmk
Thread: Family Hitbox Too Large
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    225
    01:36 PM
    When I loaded a air valve family I created into a project to test it out I've noticed that the families "hitbox" is too large. It makes it difficult to select elements around the object. I don't know what other term to use other than hitbox. By that I mean the area on the screen where clicking will select the family. It extends beyond the extents of the object itself. I'm wondering if this may be due to clearances that can be hidden.
    If there is a better term in Revit related to this problem please let me know because I could not find anything online with the terms I've used.
    jmk
    jmk is online now
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,425
    11:36 AM
    Edit the family and take a look at it. I've had families behave like that which have either large hidden elements, but also stray reference plans/lines that are away from the modeled element. Check the reference planes first. However I know I did have to modify a fire extinguisher family that had circles representing their coverage area so that when the coverage wasn't visible it was a very small circle.
    CRapai likes this.
    April 30, 2015
    Michigan
    225
    01:36 PM
    Thanks jmk,
    It was weak references. Can't believe I was so careless. Set them to not a reference and the family is working much better.
    jmk
    jmk is online now
    December 31, 2012
    NM, USA
    1,425
    11:36 AM
    Great!
    I had one where it was a reference plane that was 20' away from the origin of a part that was then nested into the family - that took awhile to track down!
  1. How to use worksets on a large project?
    By joewallace in forum Architecture and General Revit Questions
    Last Post: February 9th, 2017, 07:35 PM
  2. Extremely Large File
    By rascule in forum Architecture and General Revit Questions
    Last Post: May 11th, 2015, 04:33 PM
  3. Large pdf
    Last Post: March 9th, 2015, 12:36 PM
  4. Large Support Files
    By cheinaranta in forum Worksharing, Revit Server & C4R
    Last Post: January 2nd, 2014, 05:41 PM
  5. Large Projects
    By Alex Cunningham in forum Architecture and General Revit Questions
    Last Post: June 1st, 2011, 03:55 PM
