I'm having trouble with a parameter in this heat pump family I'm trying to make. There are a ton of sizes and different configurations but I want to limit this to one family. Instead of having dozens of types I've decided to limit the types to the unit sizes (6) and use instance parameters to deal with the different Left/Right hand configurations of the unit. I've managed to create a return connector that can rotate to the correct hand, but now I'm having trouble changing the size of it. The Width of the return also controls it's position and the center point for it's rotation. When I try to change the return width "A_Return_Width" I get "Constraints are not satisfied." I'm using a nested family for the return box.
The funny thing is I can move the Reference plane that is controlled by "A_Return_Offset Return Width" manually and it will change and the return width will change as well.
