Results 1 to 5 of 5
Like Tree2Likes
  • 2 Post By josephpeel
Thread: Annotation families??
    September 10, 2014
    21
    07:57 PM
    ok so i am hoping that this is going to be something that i will be able to get out of my head and on here so someone can understand.
    i am in plumbing and we use flow arrows, i hate the fact that when you place them and end up having enlarged views, then have to move your piping. now i have to go and clean up all the flow arrows from the changes. i know that you are able to put a flow arrow on your piping, and then if you select it, move it off and then place it back on with the piping highlighted it will give you a little locket. if you click this you are able to lock that annotation symbol, flow arrow or whatever you want to call it to that piping. so if you move the piping the flow arrow will move with it.
    is there a parameter that you can add to be able to get this? and make it so i dont have to re-select it move it off and back on to get that locket to show up? i am being told that this is a stupid idea and a waste of time. anyone have any thoughts.
    Attached Thumbnails Attached Thumbnails Annotation families??-flow-arrow.jpg   Annotation families??-flow-arrow2.jpg   Annotation families??-flow-arrow3.jpg
    May 3, 2012
    1,396
    04:57 AM
    a) This is the kind of 'CAD Standard' stuff that I try to avoid at all costs in Revit... They have to be manually placed, there is no way to automatically get the flow direction so you have to check and rotate every one, if the pipe is moved or deleted you have to go and clean up this sort of crap on multiple views..... so ask why you need to do this and if it is worth valuable hours of your life.
    b) If you must do it then use a Tag. The advantage of a tag is it will always move with the pipe and disappear if you delete the pipe. Make sure the origin position in the tag is correct so that it gets placed correctly on the centre line of the pipe. If you select 'rotate with component' then the tag will pick up the orientation of the pipe, but you will still have to make 2 Types for the different flow directions.
    cganiere and Necro99 like this.
    April 30, 2015
    Michigan
    201
    10:57 PM
    You could also use a fitting but I'd generally advise against adding a bunch of extra stuff to the actual piping. We've been using symbols and had the same issues with moving pipe. The tag idea is great. I just made one in about 3 mins from the inline pipe tag although mine is acting strange. I can place it on the pipe or above it....
    January 17, 2011
    1,982
    09:57 PM
    Definitely going to back josephpeel regarding a Tag.
    Quote Originally Posted by CRapai View Post
    Bad Revit!! Don't do it! lol... just kidding. But not really.
    -TZ
    February 22, 2013
    317
    10:57 PM
    I use a simple tag family for this as well. Like Josephpeel said, it's annoying because the flow direction is manually selected, i.e. fallible. One the one hand, I wish that Revit could get the flow direction from the Piping System. On the other hand, very often I don't bother connecting every object in a plumbing system (to save time/$) so the system isn't reading any flow anyway. Relying on Revit to determine flow direction would require me to make sure that every plumbing piping system was modeled and "working" in the model, which I simply don't have time for. I'll do it for Duct Systems, but not a basic office building plumbing system.
    My tag family has a label that displays the System Abbreviation, and left/right arrows. The arrows' visibilities are controlled by yes/no Type Parameters, and the Tag family has two types, one for Left Arrow and one for Right Arrow.
    Attached Thumbnails Attached Thumbnails Annotation families??-pipe-flow-tag.png
  1. Add system annotation families in a Legend
    By MARIA1993 in forum Architecture and General Revit Questions
    Last Post: August 1st, 2017, 09:08 AM
  2. Nested annotation families graphics and visibility overrides
    By Mat at YourCad in forum MEP - Family Creation
    Last Post: January 15th, 2015, 08:59 AM
  3. Annotation Families & Filled Regions
    By Matt_Short in forum Architecture and General Revit Questions
    Last Post: May 6th, 2014, 03:20 PM
  4. generic annotation in face based families
    By ekkonap in forum Tutorials, Tips & Tricks
    Last Post: November 15th, 2012, 03:57 PM
  5. Shared Parameters in Annotation Families
    By Kevin McCurdy in forum Architecture - Family Creation
    Last Post: November 5th, 2012, 05:32 PM
