Results 1 to 1 of 1
Thread: Different Led-array's in Profile
    October 18, 2016
    26
    04:40 AM
    Hi all,
    There is maybe a easy solution for my question but i'm breaking my head on it for the moment . .
    I have this profile, where you can add different LED array to it.
    The Profile has a family and each LED-array too
    Our client requested 4 formats :
    3110mm - 12W and 48W
    6200mm - 2x 48W and 36W
    2260mm - 48W
    1710mm - 36W
    I would like to add them all into the profile family.
    for example:
    If the profile is 3110mm long, there should be a 12W LED-array (560mm) and a 48W LED-array(2240mm) inside the profile.
    Is there a way that you can make them "auto-select and -align" into the profile-family?
    Or should i just make a checkbox for each LED-array family so I can check/unckeck them on each a different Family type ?
    Greetings,
    Alexandre
    Attached Files Attached Files
  1. Profile Sweep, Family type profile parameter
    By spinxy in forum Structure - Family Creation
    Last Post: January 11th, 2016, 05:56 AM
  2. Using a profile parameter to define a sweep profile within a family
    By mattsim in forum Architecture - Family Creation
    Last Post: May 16th, 2013, 04:47 AM
  3. Replies: 4
    Last Post: March 14th, 2013, 02:31 AM
  4. Replies: 0
    Last Post: February 7th, 2012, 04:45 AM
  5. Wall profile edit - where's the profile outline?
    By DDenton in forum Architecture and General Revit Questions
    Last Post: August 8th, 2011, 08:48 PM
Tags for this Thread
