Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Like Tree3Likes
Thread: Creating a slope with a simple extrusion family
    October 18, 2017
    6
    08:43 PM
    Good day Family creators,
    I've been looking to create a simple extrusion with a slope on the bottomside.
    From all the forums and videos that I looked up, none gave me a satisfying answer.
    I also contacted the stabicad helpdesk with the same question but I doubt they can give me a proper solution for my issue.
    I've created a couple of Reference Planes and a reference Line for the angular parameter.
    Then I added the formula 'Atan(Rise/...mm)'.
    I tested if the slope worked and it does. But as soon as I make an extrusion and lock it on the reference planes and line I get the well known error 'Constrains are not satisfied' when I change the slope steepness.
    Could you maybe tell me what i'm doing wrong?
    A little help would be greatly appreciated.
    The family is attached.
    -Michael
    Attached Files Attached Files
    July 7, 2011
    Rotterdam, Holland
    1,228
    09:43 PM
    Looking at your family I see that you did not lock the sloped line of the extrusion to your ref line. After doing that it works fine for me.
    oh and welcome to the forum of course!
    October 18, 2017
    6
    08:43 PM
    Quote Originally Posted by Robin Deurloo View Post
    Thank you!
    Strangely enough it still doesn't work. I indeed forgot in my haste to lock the Reference Line to the Reference Level.
    I went on and did that, drew the extrusion and locked it to all Reference planes and the line that I needed.
    Then changed the angle of the Slope parameter and it still gives the error..
    July 7, 2011
    Rotterdam, Holland
    1,228
    09:43 PM
    Geen probleem
    No clue what's going on then.
    Find attached the family I edited and works fine for me.
    October 18, 2017
    6
    08:43 PM
    Geen probleem
    Very weird, I opened up your family and took a look.
    I noticed that the Reference Line wasn't locked on the reference level?
    Basically all you did was lock the bottomside of the extrusion on the reference Line and it worked? Because when i do the same it still gives an error..
    I think i'm missing something here
    July 7, 2011
    Rotterdam, Holland
    1,228
    09:43 PM
    Yep, that's all I did. Does the family I edited work for you?
    Tried to edit all the parameters and no problem
    Tried it in a project as well and all is OK there too.
    October 18, 2017
    6
    08:43 PM
    Mysterious...
    Yes your edited family works as i want it to work.
    When i do the exact same thing it comes up with 'constrains are not satisfied..'
    Tried making an entire new family and it once again gives the error...
    July 7, 2011
    Rotterdam, Holland
    1,228
    09:43 PM
    Mysterious indeed
    I have no idea what could be the problem
    October 18, 2017
    6
    08:43 PM
    This is very frustrating.. I've been trying anything I can think off but nothing seems to work..
    Would you be so kind to describe it to me step by step what you did exactly? Because I truly think i missed a very important small thing.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    03:43 PM
    I've found it best to constrain the reference line to your reference planes as required, and make sure to constrain the shape to the reference line.
    https://www.screencast.com/t/sd0yzkNwL
    cganiere and TomekTomek like this.
  1. Simple way of creating Revit Diagrid
    By polyplop in forum Architecture and General Revit Questions
    Last Post: July 5th, 2016, 10:48 AM
  2. Allow the Family host extrusion to move together with void extrusion
    By JiaQing in forum Architecture - Family Creation
    Last Post: March 6th, 2015, 04:21 PM
  3. Creating a ceiling with slope
    By asakaoka in forum Architecture and General Revit Questions
    Last Post: September 30th, 2013, 02:18 PM
  4. creating custom shapes in roof by extrusion
    By RevitHatter in forum Architecture and General Revit Questions
    Last Post: May 30th, 2013, 07:03 PM
  5. Help with creating simple .pat file in notepad
    By maddyjdel in forum Architecture and General Revit Questions
    Last Post: September 8th, 2011, 08:09 AM
