Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By ebc
  • 1 Post By Allu
Thread: Rotating Family in Section View
    July 12, 2017
    18
    01:26 PM
    Hello,
    I created a generic angle iron family. Then loaded it into my project and noticed I can't rotate it if I am in a front section view. Any quick fixes?
    ebc
    ebc is offline
    New Member ebc's Avatar
    January 11, 2018
    Calle Nueva Ocho, oficina nueve – 31192 Mutilva Alta – Navarra. Spain
    2
    02:26 PM
    Hi there! I'm afraid you can't rotate a level restricted family. It must always maintain the horizontality of its level of reference.
    You still have two options. They are not 'quick', but they can fix it if you are in the need:
    - You can edit the family to give the rotation you want. if this is a singular case.
    - If you want to rotate it at will when placed in the project, you can nest your family in another family, by creating a reference line in the new family and selecting one of its reference planes as the nested family's work plane, and parametrize that line's rotation.
    Elías Bermejo / Building Engineer - BIM Consultant.
    www.espaciobim.com
    modedit: removed logo. Please take a look at the forum rules & guidelines on signatures: https://www.revitforum.org/forum-sug...rum-rules.html
    cganiere likes this.
    October 18, 2016
    26
    02:26 PM
    Hi swooll3,
    Rotations can be hard to learn. But once you know how to do it, it's all just a piece of cake.
    I used to refer to this site to help with rotations:
    Rotating a Revit model family in 3 different axes, by reference lines - Planta1
    Good luck
    josephpeel likes this.
    May 3, 2012
    1,381
    02:26 PM
    Good example, but there are several ways to do this. You can do the same with 2 families instead of 5.
    If you use Reference Lines you can place them on the workplane of another ref line.
    So in the 'Family 2' example you would place one ref line for the horizontal angle, then on the vertical plane of that ref line, place the ref line for vertical rotation.
    The vertical line will keep its relation to the horizontal line reliably even when it moves.
    Finaly lock the 3D family to the second ref line and it should be good to go without linking any parameters between families..
    I use this for movable MEP connectors.
    If you want it to move as well as rotate then it is neccesary to put it inside a 3rd family.
    Attached Files Attached Files
  1. Replies: 15
    Last Post: March 5th, 2017, 06:01 AM
  2. Rotating a View
    By floridashaughn in forum Architecture and General Revit Questions
    Last Post: March 1st, 2016, 02:16 PM
  3. Family view in sheet/cut section
    By txelwood in forum MEP - Family Creation
    Last Post: April 2nd, 2014, 07:43 PM
  4. My family tutorial for rotating an object 360° in any view.
    By B3DStudios in forum Architecture - Family Creation
    Last Post: November 20th, 2012, 11:22 PM
  5. Replies: 0
    Last Post: August 30th, 2012, 05:15 AM
