Results 1 to 3 of 3
Thread: Associated(Face-based) families with auto rotated Tag(Symbol)
    October 31, 2017
    New Zealand
    1
    07:51 AM
    I'm having problems using face-based family such as socket outlets, while I'm showing the tag(symbol) as a separate family in 2D. The reason I'm having a separete family for the tag is I sometimes show/locate the tag apart from the actual geometry for some reason. And what I need to know is how to get the tag rotated automatically while I locate the geometry in different directions.
    Any thoughts are appreciated.
    Member Darius's Avatar
    May 6, 2013
    484
    02:51 PM
    if the tag is part of the family as you've probably found the tag will rotate with the family giving you tags that are upside down and backwards... if this is the case then you will need to have at least 4 tags in the family for left, right, top, and bottom so the tag will always appear readable.
    however if this item appears on walls that are at an angle you will need to add tags accordingly.
    Also having tried this i would recommend against it this creates messy families and unmovable tags which will create problems
    December 21, 2010
    Phoenix, AZ
    2,599
    11:51 AM
    I’d add a rotational parameter to the nested GA.
  1. Face Based Light Fixture Annotation Symbol
    By bob_oregon in forum MEP - Family Creation
    Last Post: May 10th, 2016, 04:10 PM
  2. face based plan symbol
    By elton williams in forum Architecture and General Revit Questions
    Last Post: November 2nd, 2013, 10:51 PM
  3. Face based family annotation symbol
    By domsib in forum MEP - Family Creation
    Last Post: August 28th, 2013, 04:44 PM
  4. Proxy face in Face Based families - delete it?
    By Gordon Price in forum Architecture - Family Creation
    Last Post: February 5th, 2012, 07:07 PM
  5. Face Based VS Wall Based VS Non-Host with Void Families
    By Parametric Snowman in forum Architecture and General Revit Questions
    Last Post: December 16th, 2011, 03:20 PM
