Results 1 to 3 of 3
Thread: Altering how 3D Models are Respresented in 2D?
    October 18, 2017
    4
    04:38 AM
    I have been trying to figure out a way to be able to be able to link a 3D model with a 2D symbol so that I may quickly switch between the two and maybe give some automation to it. For example, when I place a 3D model of some valve, it shows in our plan view in 2D and the symbol that Revit uses to represent it is not necessarily the symbol that our company needs to use.
    I have been looking around for a solution, however the best I can find right now is I have been told to hide the valve models in my plan view and then just lay over the symbol of my choosing. Does Revit have a way to control how a 3D model is represented in 2D? Or is there another solution, maybe some form of scripting?
    Gold Coast
    2,621
    02:38 PM
    In the family editor select your geometry and hit the visibility settings button...
    Help
    February 22, 2013
    333
    12:38 AM
    I've found that the best way to deal with this 2D/3D problem is to nest 2D Graphic Annotation families into my 3D Pipe Accessory/Fitting families. Set the GA family to be visible at Coarse detail and the 3D objects to be visible at Fine detail. This method will NOT work with sloped pipe. (I don't care because I don't slope pipe in my models unless it's absolutely necessary.)
    I've also recently found a way (thanks to Josephpeel) to attach images to the families and schedule those images on my cover sheet. The images are of each valve's 2D appearance (I had to hand make them with MS Paint...) and the Legend schedule will auto-populate as they're added to the model. It took a lot of set-up and trial-and-error but I eventually got it to work with all of my piping and duct accessories and fittings.
  1. Replies: 0
    Last Post: March 31st, 2017, 08:45 PM
  2. Altering the default text of the Color Fill Legend
    By Lox in forum Architecture and General Revit Questions
    Last Post: December 15th, 2013, 06:11 PM
  3. Altering Detail Component Linetypes
    By Jock in forum Architecture and General Revit Questions
    Last Post: November 5th, 2013, 11:22 AM
  4. Altering existing room information
    By mhug9 in forum Architecture and General Revit Questions
    Last Post: October 8th, 2013, 04:56 PM
  5. Altering drawing list
    By UKN in forum Architecture and General Revit Questions
    Last Post: February 28th, 2012, 08:12 AM
