Results 1 to 3 of 3
Thread: Connectors in array - is it possible?
    May 28, 2017
    8
    01:44 PM
    Hello,
    I have just created a family - pipe collector. I can easly modify amount of connections by typing the number. It changes the length of the whole collector and number of connections. But I have a problem to actually set the pipe connectors. Revit refuses to put connectors into the array. So my family is uselss because i cant actually connect it to pipes. It is just an empty block. I can set them manually to every type of collector but thats not a point. What if i have collector with 20 connections? Do I have to build it manually?
    Any idea how to create such a families with multiple connectors?
    Regards
    May 3, 2012
    1,396
    02:44 PM
    This does work if you first set your array to the max number of connections you expect, then place a connector on every pipe extrusion.
    Then if you reduce the number of connections in the array, the extra connectors should disapear with the extrusions.
    May 28, 2017
    8
    01:44 PM
    Thanks! That is good enough for me
  1. Connectors
    By Rev Dawg in forum MEP - Family Creation
    Last Post: November 7th, 2016, 06:58 PM
  2. Mixing tap connectors
    By nick_h in forum MEP - General
    Last Post: August 31st, 2015, 03:30 PM
  3. Disappearing Connectors in Families
    By becciasm in forum MEP - Family Creation
    Last Post: March 20th, 2013, 06:06 PM
  4. Pipe Connectors move........
    By Ch2M_MikeMaloney in forum MEP - General
    Last Post: October 3rd, 2012, 09:20 AM
  5. Replies: 0
    Last Post: February 7th, 2012, 05:45 AM
