Results 1 to 3 of 3
Thread: Adding two parameters in family
    May 1, 2017
    8
    07:20 AM
    Hello,
    I am trying to add a parameter to my labels in my scene switch family, I am having to group the label and annotations of the family together so i can add offset type parameters. i also already added veritcal and horizontal type parameters to the family so my labels will flip around depend on what side the family is hosted to. my problem now is, i need my label to be a type parameter for the switching so i can change the text in the properties in my project. is this even possible. all help is appreciated thank you!!
    February 6, 2015
    85
    02:20 PM
    Do you want to switch between preset tags for the family (i.e: One type will have "Scene 1" as a tag, another will have "Scene 2" as a tag...etc), or are you looking for the text in the tags to be editable within the project?
    May 1, 2017
    8
    07:20 AM
    Quote Originally Posted by mkisno4 View Post
    I found that just using tags instead of labels is what is going to work best. I was trying to edit families that were created prior to me working in revit. I am still semi-new. but have convinced the office tags are the right way.
  1. Adding parameters to Circle
    By joewallace in forum Architecture - Family Creation
    Last Post: November 1st, 2016, 02:22 PM
  2. Adding family parameters to text file/type catalog?
    By mkisno4 in forum Architecture - Family Creation
    Last Post: April 29th, 2015, 03:15 PM
  3. Adding Multiple Parameters
    By nick_h in forum MEP - General
    Last Post: December 17th, 2014, 11:21 AM
  4. Adding parameters to groups
    By Cyus in forum Architecture and General Revit Questions
    Last Post: March 27th, 2014, 12:37 AM
  5. Adding parameters to a Keynote tag.
    By adamdr1 in forum Architecture and General Revit Questions
    Last Post: February 11th, 2013, 06:07 PM
