Results 1 to 2 of 2
Thread: Revit Types management: Light Fixture
    August 2, 2011
    Lecco, Italy
    1
    02:05 PM
    Hi everybody,
    I am trying to solve this matter: I am creating a catalogue of lighting fixtures, which contains a lot of types due to the fact that each type has its own .ies file. Exporting the FamilyType.txt with the procedure explained here: https://processinnovation.wordpress....oghi-dei-tipi/
    (sorry for the Italian link). When I export the types with the light source I have the error "the input contains invalid parameters or values for....<name of the family>", then, when I delete the flag "light source" in the Family Category, the importing has no mistakes and everithing works.
    Is there a way I can use to export and import a.txt familyType that helps me managing the ies parameters?
    Thank you so much for your help!!
    October 18, 2016
    26
    01:05 PM
    Hi Zimo,
    It can be helpfull if you add your family to this tread, so we can check what's wrong.
    Greetings,
  1. Light Fixture not Recognizing Light Source
    By BD Mackey in forum Architecture - Family Creation
    Last Post: February 4th, 2015, 11:37 PM
  2. Light Fixtures and Fixture Schedules (new to revit)
    By trohman in forum MEP - General
    Last Post: April 2nd, 2014, 03:53 PM
  3. Adding a light fixture on Revit 2013
    By ChrisInTexas in forum MEP - General
    Last Post: February 14th, 2014, 06:38 PM
  4. Revit OpEd: Light Fixture Grid Positioning and Wires
    Last Post: August 22nd, 2013, 08:45 PM
  5. Replies: 0
    Last Post: September 17th, 2011, 03:01 PM
