Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
Like Tree5Likes
Thread: Turning off or hiding unused connectors
  1. #11
    Orlando, FL, USA
    3,141
    01:31 AM
    Quote Originally Posted by CRapai View Post
    ... was thinking that you could probably fake in the connector symbol with a nested generic annotation family so that it would only show in non-3d fine detail views. I haven't actually experienced having a connector without being able to see it so I'm not sure if this would mess with the functionality of it.
    What would you achieve by faking a connector, replacing it with a generic annotation?
  2. #12
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    258
    01:31 AM
    Let the designer know where the connector is located.
    Help them realise they are using the correct family type.
    If seeing the connector isn't useful then why show them at all? Just tell autodesk to remove them. MEP will love it.
  3. #13
    Orlando, FL, USA
    3,141
    01:31 AM
    I really don't understand your point.
  4. #14
    April 30, 2015
    Michigan
    258
    01:31 AM
    Steve mentioned a workaround using nested families that could turn on/off connects with the side effect of never generating the graphic for the connector, even when the nested family is visible. Creating a fake connector would be a workaround for the workaround which would make the family more useable...potentially.
  5. #15
    Senior Member Alex Page's Avatar
    December 13, 2010
    Wellington, New Zealand
    660
    05:31 PM
    But if its a fake connector, you wouldn't beable to connect anything to it - or am I missing something here?
  6. #16
    Mr. Revit OpEd
    2,954
    10:31 PM
    I think the suggestion is a symbol might help someone know there is a hidden connector (in by a nested family). A symbol will change size (annotation) so it's position will shift and not be a reliable indication of where the connector should be found. A detail line that could be turned on and off might be better...assuming any of this is better than putting the connector right in the family directly.
  7. #17
    April 30, 2015
    Michigan
    258
    01:31 AM
    Quote Originally Posted by Steve_Stafford View Post
    I think your right. A detail line would probably work better. I think you could do it with a symbol but if you wanted to control the position with non-annotative scale that would also have to be nesting in a faced based family and getting the orientation correct would be difficult in some families.
  8. #18
    Orlando, FL, USA
    3,141
    01:31 AM
    Nested or hidden connectors are useless in the project. I still don't see what you would gain by putting a detail item or an annotation family to represent a connector.
    Really? It seems to me that connectors are essential for the software to create systems and produce information such as flow, voltage, pressure, etc,
  9. #19
    April 30, 2015
    Michigan
    258
    01:31 AM
    I meant the visual representation of of them. Also sarcasm.
  10. #20
    Mr. Revit OpEd
    2,954
    10:31 PM
    Quote Originally Posted by Alfredo Medina
    ...Nested or hidden connectors are useless in the project...
    My original reply was that a nested family with a connector will still allow connection to a circuit/system. The issue was that it wasn't visible and I have to know it is there...somewhere. I haven't tried it since then so I don't know if it still works or if they blocked that quirky situation.
  1. Purging unused Patterns
    By B Arch in forum Architecture and General Revit Questions
    Last Post: March 10th, 2014, 10:15 AM
  2. Remove unused files
    By Kasper89 in forum Architecture and General Revit Questions
    Last Post: March 6th, 2013, 01:26 PM
  3. Purge Unused - Consequences?
    By brinxb in forum Architecture and General Revit Questions
    Last Post: February 16th, 2012, 03:03 PM
  4. Purging unused sub-disciplines?
    By ekkonap in forum Architecture and General Revit Questions
    Last Post: July 3rd, 2011, 08:17 PM
