Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By evan.dodds
Thread: Exit Signs
    April 29, 2011
    Pacifica, CA
    18
    08:50 PM
    Exit Signs
    We have 2016 running in our office. I just went through looking and couldn't find an Exit Sign family.
    I looked through Lighting and Fire Protection and found none. All I found was and Emergency Wall light which is just the "Bugeye" fixture. So as much as we invested in the program they can't even provide something that is an essential part of Electrical LightingDesign/Engineering as an EXIT LIGHT? What a rip off.
    Member evan.dodds's Avatar
    December 29, 2014
    Calgary, Canada
    197
    09:50 PM
    C:\Program Data\Autodesk\RVT <year>\Libraries\<library>\Specialty Equipment\Fire Protection is the default family that ships with Revit.
    You may call it a light, but it's not if you really consider it (doesn't light anything in a room...), so why would it be in the lights folder? Also, it's a box, so pretty much the simplest thing to make as you may not like the sign that ADesk provided.
    snowyweston likes this.
    April 29, 2011
    Pacifica, CA
    18
    08:50 PM
    I found that is was in a specialty folder. I've been in the electrical design environment for a while and would never to consider an exit sign a specialty item. If anything it should've been in Life Safety. but it REVIT. enough said. Carry on.
    December 21, 2010
    C.LONDON
    4,382
    04:50 AM
    I fear if the absence of a single item from OOTB provided content is enough to rile you, you're probably not going to get along with Revit very well.
    But out of interest, which software have you been using that gave you everything you needed OOTB?
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    846
    01:50 PM
    Maybe bimobject? (Search via the seek tool in insert menu)
    April 29, 2011
    Pacifica, CA
    18
    08:50 PM
    Thanks Snowyweston.
  1. Replies: 0
    Last Post: June 21st, 2017, 09:15 AM
  2. Replies: 0
    Last Post: August 16th, 2013, 04:15 PM
  3. Emergency Lighting battery pack, remote heads & exit signs
    By skoko in forum MEP - Family Creation
    Last Post: June 19th, 2013, 02:05 PM
  4. Can't exit edit mode
    By lukewallace1990 in forum Architecture - Family Creation
    Last Post: December 8th, 2012, 10:38 PM
  5. exit signs not visible in floor plan
    By byork in forum Architecture and General Revit Questions
    Last Post: December 3rd, 2012, 08:07 PM
