Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By josephpeel
Thread: Pipe Accessories recognition in system
    July 28, 2017
    1
    04:17 AM
    Hi people.
    Have a question about pipe accessories.
    I created a family – Isolating Valve.
    In the “Family Category and Parameters” its saved as pipe accessory/valve – normal.
    Downloaded into the project and shown under “Pipe Accessories” in the project browser.
    When I try to place it on top of the pipe which is part of piping system it picks up center of the pipe but when I click it. Revit drops valve to the 0.0 offset and its not part of the system or pipe, just separate object.
    Im confused, do I have to place connectors on every pipe accessory and if yes do I have to create same families of valves for different systems? Or any advise why Revit couldn’t recognize my pipe accessory.
    Thanks
    May 3, 2012
    1,396
    04:17 AM
    It should have 2 connectors that are Fitting or Global. Then it will take on the system of the existing pipe.
    Use Global connectors when you need to know the flow through the pipe accessory in the family itself.
    But Fitting works better with sizing the pipes.
    If that doesnt work then try using 'Breaks Into' or 'Valve - Breaks Into' in the family options
    herman30ph likes this.
  1. Show Sleeves, Hide Valves & Other Pipe Accessories
    By koolair in forum MEP - General
    Last Post: May 12th, 2017, 12:19 PM
  2. Replies: 2
    Last Post: December 24th, 2015, 05:56 PM
  3. Pipe Accessories Schedule
    By nick_h in forum MEP - General
    Last Post: November 26th, 2014, 02:19 PM
  4. Replies: 0
    Last Post: November 24th, 2014, 01:15 PM
  5. Square/Rectangular Pipe: Is there a System Pipe this shape?
    By samz1 in forum Architecture and General Revit Questions
    Last Post: March 6th, 2014, 12:22 AM
