Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By Twiceroadsfool
  • 1 Post By cellersick
Thread: Server Rack RU elevation
    July 10, 2017
    6
    01:27 PM
    hi colleagues, i design server rooms for our company, and am now using Revit for this purpose. I am trying to do the following:
    using a Rack HOST, i am trying to use the schedule information and automatically place the desired family items at specific rack RU levels.
    the Rack family i am using has SNAP in reference lines, BUT no designation of RU number and i don't want to manually move devices around to the right position.
    eg: i would like to automatically place the following devices at these positions:
    1x Cisco 3950 at RU 3 (1U)
    1x Cisco 3950 at RU 5 (1U)
    1x Netapp at RU 7 (2U)
    and so on.
    secondly, AFTER i have done this, i would like to move the Schedule information to our CMDB via DYNAMO including room number, rack number, hostname & RU level.
    any tips that any of you can give me ?
    thanks in advance.
    10,036
    07:27 AM
    Yep. There is a thread on rack and server equipment here, already.
    You can do what you are after, provided your rack family has parameters for what type of device sits at each RU, and whether or not an item is there at all.
    Aaron Maller
    Director
    Parallax Team, Inc.
    josephpeel likes this.
    July 10, 2017
    6
    01:27 PM
    many thanks - but when i search for any of these things, nothing came up - do you happen to have a link for me?
    March 21, 2013
    Phoenix, AZ
    275
    05:27 AM
    May 3, 2012
    1,396
    02:27 PM
    IT guy at my last company did it the same way; Nested shared families in each slot with a Type Parameter to select.
    So nothing to add to this excellent example, except... "Dont spend your weekends overmoddeling all the air vents like a total lunatic"
    A general tip for using nested, shared families though;
    Add an instance parameter called "Host Name" or something. Then link this to the Description/Model/Assembly Code/Rack ID of the hosting family.
    Then when you schedule all the sub-families you can also schedule the Host Name to see where they are. Room Number should work, but if not get it from the host racks.
  1. how to connect Accelerator Server with Revit Host Server ?
    By usmanali41 in forum Worksharing, Revit Server & C4R
    Last Post: May 16th, 2017, 02:27 PM
  2. Bike rack line-based family
    By BLothian in forum Architecture - Family Creation
    Last Post: April 9th, 2014, 12:43 PM
  3. Revit Server Internal Error when trying to connect to another server
    By jespinoza in forum Worksharing, Revit Server & C4R
    Last Post: July 2nd, 2012, 10:37 PM
  4. Small office server / Revit server questions...
    By honestak in forum Worksharing, Revit Server & C4R
    Last Post: May 29th, 2012, 10:38 PM
  5. Revit Server - how many central servers can a local server serve?
    By kingjosiah in forum Worksharing, Revit Server & C4R
    Last Post: March 8th, 2011, 05:12 PM
