Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Like Tree17Likes
Thread: Need Equipement urgent
  1. #11
    January 17, 2011
    2,046
    10:02 PM
    Some Families are pretty solid, but not many. The way the MEP world is with equipment and devices, it's best to simply learn how to make your own content because it's a bottomless pit. I find it difficult to fathom many Revit MEP designers lasting for years without knowing how to fundamentally build a decent family. Clicking pipe, duct, conduit and setting things up are one thing, and many are getting that down pat. But then out of nowhere you see the old imported-DWG Trane packaged RTU with the blue-green material that bleeds through everything and shows up on all levels, and you just wonder... reeeeally? How many years now has this Family been wrecking shop on contract documents?
    Most of my things are simple LxWxH box, necessary connectors and some clearance geometry and that's it. All you need. It's really not that hard.
    -TZ
  2. #12
    February 22, 2013
    336
    11:02 PM
    You're right that family editing should be understood by everyone, but it really isn't. I'm the only one in my office who knows how. I'd consider that job security, but my bosses don't know what a family is...
    josephpeel likes this.
  3. #13
    May 3, 2012
    1,403
    05:02 AM
    One possible solution is to make generic template families that are as parametric as possible, so that it is possible to make almost anything you need using Edit Type.
    Then only a few key users need to know how to create the templates or add parameters/functionality/calculations etc. to them, everyone else just modifies the template parameters to set the size, connector positions, 3D object type and so on to match the product data of the equipment selected for the project.
    I posted something about this ages ago (2012...time flies)
    https://www.revitforum.org/mep-family-creation/10058-concept-mep-families-consulting-engineers.html
    Since then I have been using this principle to make MEP families on various projects to make all kinds of generic representations of equipment, or as a framework to load external content into. Sure, the same people who say they could never learn how to make families complain just as much about having to use the (still complex but much easier) Edit Type method and expect someone else to do it for them...
    Im about to make a new set of templates with some improvements, so heres one of my current families;
    Im happy to share it for people to play with, use it as you wish, because its been 5 YEARS! since I came up with the idea and my greatest frustration at the moment is how long it takes to get anything implemented and to convince people to try a different way of doing things....
    You can load symbols (GA or DI) and 3D models into it and select them when creating types. Theres a bunch of basic forms in there already.
    (Yes I know its pretty big for a family but theres 3D models in there that are not strictly neccessary, and making lots of types in a project is still smaller overall than adding lots of individual families)
    Attached Files Attached Files
    Necro99 likes this.
  4. #14
    April 3, 2013
    25
    03:02 AM
    Actually creating the family is easy, it's setting the correct parameters so its useable that's the difficult part
    Necro99 and tzframpton like this.
  5. #15
    Forum Addict Andres Franco's Avatar
    June 21, 2012
    Tours, France
    1,005
    05:02 AM
    I think the way to learn Revit is to face problems, sometimes a lot of them since you are a beginner , back in 2012 I modeled this family which you can find in Revit city, is not a perfect one, but I just take the manufacturer's product data submittal sheets,
    and yes "setting the correct parameters so its useable that's the difficult part"
  6. #16
    January 17, 2011
    2,046
    10:02 PM
    Quote Originally Posted by Hudster View Post
    Yes. I agree with this. There are two types of Families: Static and Dynamic. Static are non-parametric one-time set of values. It basically has one "Type" - itself. Then you have Dynamic, better known as "flexible" or "parametric", in which you intuitively create content that is driven by values and geometry. There are certainly more complex but not necessarily more difficult.
    -TZ
  7. #17
    February 22, 2013
    336
    11:02 PM
    Quote Originally Posted by josephpeel View Post
    I've done something similar for my families. I have a "Motor driven mechanical equipment" family template that has all of the electrical parameters that our schedules and electrical people need. It uses lookup tables to find the correct Full Load Amps based on the entered motor horsepower and voltage. I really like how that worked out, because I can then use this template for any kind of fan or pump. The lookup tables have the FLA data from the NEC (the US's National Electrical Code), but there's an "override" parameter you can use if you want to use a different value.
    josephpeel and tzframpton like this.
  8. #18
    May 3, 2012
    1,403
    05:02 AM
    Nice! Ive been looking at using Lookup Tables for that type of data too.
    For Mechanical stuff, like Air Terminals you can get all sorts of data from different manufacturers that could be stored in a lookup table instead of managing a huge library of families and types.
    So a generic Family, with very generic formulas (Like Pressure drop per airflow = a + bX + cX^2) and then lookup tables to list the a,b,c constants that fit each manufacturers data. Might provide a smarter way to make component selections than looking through manufacturer datasheets every time..
  9. #19
    February 22, 2013
    336
    11:02 PM
    I've started doing this with VAV Terminal Units. There are so many different kinds of these and we had a family for each. Now we have ONE family that can be a parallel, series, or single duct unit, depending on what lookup table it's using. The lookup table controls its type (parallel, series, single duct), its dimensions, and its motor FLA.
    One annoying limitation is that the lookup tables don't support text. So I had to create a numeric system to identify the various manufacturers and models.
  1. Urgent
    By Richierich123 in forum Architecture and General Revit Questions
    Last Post: September 13th, 2016, 02:43 PM
  2. (need urgent help) mep fittings missing
    By salman102 in forum MEP - General
    Last Post: May 30th, 2014, 08:12 PM
  3. need help urgent please!
    By revithelp in forum Architecture and General Revit Questions
    Last Post: October 27th, 2013, 12:57 AM
  4. I need an urgent help !
    By Mohamed 72 in forum Structure - General Questions
    Last Post: December 20th, 2012, 12:59 PM
  5. Urgent help.. Revit bug or smth..
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: June 23rd, 2011, 12:29 PM
