Results 1 to 2 of 2
Thread: Bringing STP files into Revit
    September 1, 2016
    1
    01:18 PM
    Hi Folks,
    I'm currently working on a project where it is required to bring a stp file into revit (for presentation purposes). My process was to bring the stp into autocad, then save as a dwg. I then opened a new family in Revit and imported the dwg file, but as you will see in the attached it has become distorted. I'd prefer if it was brought into family editor as I can then add a few extrusions here and there to create pipe connectors.
    The model looks perfect in Autocad, its only when I bring it into Revit. Iv had a colleague check it in solid works but it also looks perfect there, although there are a few rebuild errors.
    Overall we have 4 files where we need to do this, 2 of which have come in perfect, the other two have distorted.
    Has anyone any ideas as to why this is happening? Is it the rebuild errors? Are there any other actions I can use to get these into Revit?
    Thanks for taking the time to read.
    Attached Thumbnails Attached Thumbnails Bringing STP files into Revit-autocad-1.jpg   Bringing STP files into Revit-revit-1.jpg   Bringing STP files into Revit-solidworks-1.jpg
    June 21, 2012
    Tours, France
    937
    02:18 PM
    Hi, do you have the possibility to export the file as an IFC file which is more stable, have you already try this?, regards
  1. Replies: 0
    Last Post: March 26th, 2016, 05:15 AM
  2. Bringing in satellite images into Revit
    By cmbyrd in forum Architecture and General Revit Questions
    Last Post: January 30th, 2014, 04:34 PM
  3. Bringing settings of one Revit Project to another
    By nsoufiani in forum Architecture and General Revit Questions
    Last Post: December 19th, 2012, 01:10 PM
  4. "Lost" folder locations bringing Revit to it's knees...
    By snowyweston in forum Worksharing, Revit Server & C4R
    Last Post: October 4th, 2011, 07:28 PM
  5. Bringing Hidden Objects Back.
    By wjnaim in forum Architecture and General Revit Questions
    Last Post: July 15th, 2011, 08:49 PM
