Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By josephpeel
Thread: Piping System Creation
    May 25, 2017
    1
    11:56 PM
    Hello,
    I am a mech. designer for an engineering firm and looking to create a stainless steel sanitary tubing with tri-clamp ends for Revit 2017. I am hoping to find someone who may be able to direct me to a site where i may be able to get an already set up piping system which i can load into my project or good step by step instructions on how this may be accomplished. I am pretty new to Revit but do have a good understanding of mechanical systems and learning Revit quickly. Please help...
    Thanks, Tom
    May 3, 2012
    1,401
    05:56 AM
    Step 1 - Go to Manage -> Mechanical Setting -> Pipe sizes and segments. Make a new Segment for your RVS pipes, with the correct sizes, inside and outside diameters.
    Step 2 - Create a new Pipe Type. In the Type Properties go to Routing Preferences. Select the Segment/material you made above and max and min sizes. Now you can at least model pipes with the correct diameters.
    Step 3 - Make /get Fittings. This is the hard part. If you cant find the fittings you want copy and modify existing ones. You should think about what you actually want to do with these pipe fittings. Do you need to show every tri-clamp for visualisations? Or do you just need to ensure there is sufficient clearance space for the fittings? It may be better (Much easier, faster with less detail) to just model a fat cylinder that reserves enough space for the clamps.
    Step 3 - Set the prefered fittings in routing preferences.
    Andres Franco likes this.
  1. VRV Piping System Name
    By brane1012 in forum MEP - General
    Last Post: November 6th, 2016, 12:39 PM
  2. MEP piping system set-up
    By davezinger in forum MEP - General
    Last Post: May 26th, 2015, 02:12 PM
  3. Piping System Classification
    By RStiles in forum MEP - General
    Last Post: July 16th, 2013, 01:38 PM
  4. More than one elbow for one piping system?
    By Gabriel Black in forum MEP - Family Creation
    Last Post: March 13th, 2012, 06:34 AM
  5. Sizing of water piping system
    By Crfield in forum MEP - General
    Last Post: December 16th, 2011, 02:26 AM
