Results 1 to 3 of 3
Thread: Duplicating Materials without linking/cloning the Apperance Properties
    July 11, 2014
    46
    03:54 AM
    Angry Duplicating Materials without linking/cloning the Apperance Properties
    I've got to say the material editor in Revit (albeit v2013) is absolutely terrible compared to other software I use and it has a really annoying bug/feature.
    That being, When you take a stock material, change it to get it like you want it, then duplicate it to create a variant (as you want the same properties except maybe the tint colour) the tint colour on the copied version then changes the original material at the same time! Agghhh! why is this? and how do I stop it happening without having to start from scratch each time for each additional variant of the same custom material?
    Help on this would be great
    Thanks guys.
    Michael
    July 11, 2014
    46
    03:54 AM
    Ok I got it, right click the appearance tab on the duplicate and hit duplicate after you've already duplicated it. Stupid, stupid, stupid, system
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    844
    12:54 PM
    Two things at play here, material and asset. The one asset can be used by more than one material. If you are planning on rendering, you need to duplicate the asset too. The liitle hand symbol shows you how many other materials are using that asset. The online help explains it, just press F1
  1. Override apperance in Hidden line mode
    By polyplop in forum Architecture and General Revit Questions
    Last Post: July 7th, 2016, 06:25 PM
  2. access Appearance properties of materials
    By kukuzry in forum Third party Add-Ins, API and R&D
    Last Post: May 2nd, 2014, 04:26 PM
  3. Schedule apperance problems
    By kanokongen in forum Architecture and General Revit Questions
    Last Post: February 19th, 2014, 11:06 AM
  4. Linking a Tag to Filled Region Text Properties
    By truthjusticeUSAway in forum MEP - General
    Last Post: September 13th, 2013, 03:27 PM
  5. Materials and Render Properties
    By Steve Faust in forum Third party Add-Ins, API and R&D
    Last Post: April 17th, 2012, 09:53 PM
Tags for this Thread
